Just loosen oil plug and drain...take out pan bolts... drop down...make sure alt gasket material is off of both pan and bottom of motor. Lay new gasket on oil pan...possibly use gasket sealer to keep gasket in place...a very thin layer on oil pan then put gasket on. Let dry for a bit then bolt back up...make sure oil plug is back in then refill....cheers!
The noise might be coming from a belt, tensioner, alternator, idler pulley or a pump. Valve body gaskets, drain plugs, and other parts have gaskets. They might leak over time, and will need to be replaced. Sometimes bolts get loose, and then the gaskets leak.
Check oil by draining. Trans tank on radiator bottom may be oily slick you see if oil pan drained clean. Then trans is probably contaminated with antifreeze and that's what is mixing.
Crack in head passages could link oil and water, if you verify antifreeze and oil mixed in oil pan.
We performed exactly the same repair on December 28, 2010 withexactly the same outcome. Finding no other references to this oil pressureproblem anywhere on the internet and the fact that they both happened the samemonth, I can only wonder if there are some incorrectly made gaskets hitting theshelves.
sounds like you are looking at the big BELL HOUSING on the front where the trandmission bolts up to the engine
If the bolts were loose then it may ave ben repaired previously
there is a seal for the front pump for the trans in there & will ned replacing
Cheers Rob
It shouldn't be hard on that car as the oil pan is exposed. Unplug the oil plug and drain the oil. Then unbolt the oil pan, clean off the old gasket and replace. Make sure you scrape both the pan and the block clean thoroughly and then bolt back up. Don't forgot to replug the drain plug.
THIS IS STRANGE, BECAUSE THE NEXT PAN BEHIND THE OIL PAN IS THE TRANSMISSION PAN. UNLESS MECURY HAS DEVELOPED SOME STRANGE SYSTEM THERE SHOULD BE NO WATER OR COOLANT ANYWHERE IN THAT LOCATION? IF THE PLASTIC PLUG IS LEAKING IT CAN BE FIXED BY REMOVING IT AND WRAPPING THE THREAD WITH TEFLON TAPE AND RE-INSERTING IT AND TIGHTEN IT. IT THE PAN ITSELF IS LEAKING, THERE ARE ONLY TWO THINGS HERE. ONE, YOU CAN RE-TIGHTEN THE BOLTS TO SEE IF THEY ARE LOOSE AND SEE IT THIS STOPS THE LEAKING. OR, IF THE LEAKING DOESN'T STOP, YOU NEED TO REPLACE THE PAN GASKET WITH A NEW ONE AND REFILL THE TRANSMISSION WITH NEW OIL. YOU MIGHT AS WELL CHANGE THE FILTER WHEN YOU HAVE THE PAN OFF, BECAUSE IT IS PROBABLY OVERDUE. I THINK YOU WILL FIND THIS LEAK IS A STICKY RED FLUID CALLED ATF OR AUTOMATIC TRANS. FLUID. THAT WILL NEED TO BE REPLACED. NEW FILTER, NEW GASKET RETORQUE THE BOLTS, IMPORTANT, DON'T WANT THAT THING FALLING OFF, NEW FLUID, YOUR BABY SHOULD PURR AND NOT WIZ ON THE FLOOR ANYMORE. NOT SURE HOW TO DO ALL THIS? BEAT FEET TO THE NEAREST PARTS STORE AND BUY OR ORDER THE CHILTON OR HAYNES MANUAL FOR 93GRAND MARQUIS AND YOU WILL HAVE PICTURES AND STORIES YOU WON'T BELIEVE! CAN'T GO WRONG! GOOD LUCK!
