Blade turns very slowly and will not grind coffee beans. Wife, God love her, may have ground nuts with it.
1. This fixes almost all the "beans will not feed or beans will not grind" problems unless you need a factory part for repair.
a. Pour all the beans out the top.
b. Open the settings up all the way and see what else can be poured
out. Use your shop vacuum to **** grounds out the spout and backward
out the bean bin.
c. Pour in some instant rice and start grinding. Reduce the grind to
a small setting like six and then open the settings all the way again.
(The grinder will not start at a low setting with the rice in it. If
you let it stop, open the settings to about 16 before trying to
restart.)
d. Pour out the rice and vacuum out the ground rice.
e. Adjust the grinder to your favorite setting and try a coffee grind.
Your machine will probably need service. The water will cause damage to the grinder burrs. I can send you instruction on how to clean out the grinder on a Vienna if you provide me will your email address. You can email me at [email protected].
You are not the first person to do this. These problems come in at least once a week.
Hope this helps.
Johnny
