Computers & Internet Logo
Posted on Nov 25, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the bios password for toshiba satelite a215-s7416
Anonymous
Level 2:
  • Expert 255 Answers
  • Posted on Nov 25, 2009
Anonymous
Expert
Level 2:
Answers
255
Questions
0
Helped
129338
Points
807
You will have to have your bios reflashed.
How to stop constant beeping on bootup after BIOS update and Windows 7 installation?
I know when I flash my bios a lot of things go through my mind until it is over because the last thing i want to see is the computer shutdown. To answer your question it is possible the update you received may have had errors in the files causing the computer to go on a beeping rampage.The only thing I can suggest is contact Toshiba's customer and technical support system to try and get answers.
I didnt set my bios password on my toshiba satelite a215 s 4747 but a password is there, how do I reset it please ? I cant find the jumpers under the ram. Thanks
If you find that this is information was helpfulto you, please rate me and leave a comment as this will encourage me to do morefree work for you and others. And please let me know if there's anything else Icould help you with. Without any inputswe cannot proceed assisting... Thank you for using FIXYA! Best regards,
Junior
WHEN I TURN ON MY LABTOP WHAT I SEE IS ENTER PASSWORD (BIOS).SATELITE A215-S7444
if you forgot password remove mainboard battery for 5 min will clear all passwords
1helpful
2answers
My Toshiba satellite a215-s7416 is asking for a password upon startup, i dont know what the password is. The screen looks like this: (http://www.r-obi.de/paperclip/locked3.png). How can I guess or remove...
Remove the ram cover, with laptop switched off
Remove the 2 ram modules and insert one in the slot that is furthest away from the motherboard
Just underneath the ram is a thin plastic sheet, gently peel back to reveal two solder contacts
they should say B500, TOUCH THESE WITH A FLAT BLADED SCREWDRIVER while powering on the laptop, the bios password should go.
Replace ram and sheet, replace ram cover reboot.
1helpful
Toshiba satilite a215 s7422 bios password how to cleare
You'll need a special tool that only Toshiba has. I believe you can get yours cleared for FREE if you tell them that all of a sudden out of nowhere you have a bios password. Stick to that story because they've already admitted to the problem with many of their laptops. You'll have to find an authorized Toshiba repair center to take care of it for you. Otherwise I believe they charge around $100 to clear it.
Don't bother to try the cmos battery trick, it doesn't work on your model. The password is stored on an onboard chip.
1helpful
Built in hdd user password
You can't
Once the Hard drive is locked by a password,The only way to use it is to have the password.
Toshiba satellite A215-S7416 clearing a bios password
Contact Toshiba service they have a special hidden program (rootkit?) they can activate on your PC.
Locked myself out of lptop goes strait 2 black & blue screen bios
Ouch, unless you know that password its not looking too good for you. take it into a computer technitian to look at it and they should be able to fix it and get it into working order again
Hope This Helps
1helpful
2answers
Satellite A215-S7416 Bios Password
There is a jumper that will clear the BIOS password on most of the newer Toshiba laptops such as this model. Here is a link to an article showing where the jumpers are located on various models of Toshiba laptops.
http://www.ccl-la.com/blog/index.php/clearing-bios-power-on-passwords-on-toshiba-laptops/
I hope this helps, if so please rate my solution.
BuddyMc
First of all i'll need to know what type of laptop it is,because different laptop has differents ways of reseting the BIOS. You can open the laptop and just take out the battery for a couple seconds and put it in back ( make sure that the power os unplugged before opening.) If the laptop has no battery then you will have to download or get a manual for the laptop hence then its going to tell you to touch 2 jumpers in order to reset the BIOS.
Grand Canyon Tech
Grand Canyon Tech
