Question about Samsung LE26R74BDX 26 in. HD-Ready LCD Television
Remove the base 26
How to remove the base on the 26"LCD TV. I removed the screwsand took the base plateform off. The neck will slide but can't be pulled out.
Posted by gfg8 on
  • Philip Frye May 11, 2010
    Is there some type of push in catch or key? If you have a user's manual it may give you a better idea or instructions as to how to remove the neck piece. Blessings, A/V Media Tech Guy
Adam Jerome_lagudi
  • 456 Answers
You may have to remove the back casing as often the neck will have a piece that prevents it from falling out. I hope this helps. If under warranty, i advise contacting the manufacturer to obtain the best way to do it as removing the back may result in a void warranty. Good Luck.
Posted on Nov 25, 2009
Chi Chu
  • Samsung Master
  • 8,457 Answers
Tries some force up or down pull,yank it out.
How do I remove the base of a Haier TV -- model number HLH26ATBB?
THERE IS 4 BIGGER SCREWS ON THE BACK OF THE TV TAKE THEM OUT AND SLIDE THE STAND OUT ....SCREWS ARE RIGHT BY AMP JACK HOOK UPS....
I HOPE THIS HELPS.. GOD BLESS..
Mar 19, 2011 | Haier HLH26ATBB 26 in. LCD Television
How do I remove the base so I can put the TV on the wall
Most TV's have the base fitted with a lock that clicks on the main frame of the LCD TV. So all you need is to keep the LCD on a soft surface like a mattress and check to see the lock linked to the main frame. Push to remove the link locks and remove the base stand.
Jan 12, 2011 | Daewoo DSL26T2WCD 26 in LCD TV
The bottom stand
Is that the 'neck' part between the flat base and the TV? You should have disconnected the neck part from the back of the TV... Instructions are in the operators manual.
Apr 07, 2010 | Samsung LE22A457 22 in. LCD TV
How do I remove the base neck from the monitor? I
theres a scre that is making the base stick to the monitor, take it out and slide out the base, or check the user manual for that
Feb 15, 2010 | LG W1934S-BN 19" Monitor
Will not change from dvd to tv mode
i had the same problem if fixed it rather simply buy using a base ball bat
Mar 15, 2009 | Mintek DTV-263 26 in. LCD Television
Need to remove base from Venturer 26'' LCD TV
look on the tv above where the base slides into the tv and you will see screws. unscrew those screws and lift the tv off of the base.
please mark my answer as a fixya!
Mar 08, 2009 | Televison & Video
I can not remove the bottom stand off the Proscan TV Model 26LB30QD to mount on wall. Any suggestions?
I have this model (ProScan 26LB30QD) and recently removed the base. There are 4 phillips head screws on the rear panel of the TV just above the base. Remove them, pull the TV from the base, and replace the screws in case you need to use the base in the future. I suspect the problem others are having is that they only removed 2 of the screws.
Nov 22, 2008 | Proscan 26LB30QD 26 in. LCD HDTV
Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
Jun 29, 2008 | Insignia LCDTV26 26 in. Television
Olevia 227V LCD
I just repaired a 26" in which the stand came off after I took the primary panel off in the middle of the back then the screws were visible that Olevia is talking about. You might have a different style but it does come off.
Feb 12, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Samsung LE26R74BDX 26 in. HD-Ready LCD Television Logo
155 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Todd Hill
Todd Hill
