Question about Canon PowerShot S2 IS Digital Camera
Is there a way to just reset the entire camera? the timer seems to be stuck and when you turn on the camera it takes pics and will not reset to take another
Posted by scherchjt on
  • scherchjt Nov 25, 2009
    Hey Typrice, that might work if I could get to that point. I turn on the camera, it takes a pic on its own and will not go back to the take a picture mode unless I change the setting then it does it all over again. so how do I just do a master reset, is there a combo of buttons I can push at start up?
Ty Price
    Brigadier General:
  • 11,967 Answers
Go into the menu and scroll to "reset"...follow the on-screen instructions.
Posted on Nov 25, 2009
  • Ty Price Nov 25, 2009
    OK...let's try a manual reset. Remove the card and battery...press all the buttons...leave it alone for 20 minutes...insert the card and then the battery...turn it on. Let me know if this worked for you.
CAnnon Powershot A630 LCD screen will not light up when trying to take a pic. I can, however view old pics that I've already taken.
First press the DISP or DISPLAY button to see if that corrects the problem. If not, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 09, 2011 | Canon PowerShot A630 Digital Camera
Everything seems to be working fine. timer, flas etc and it seems to be taking pics but when you check it there are none. have tried two different cards no luck any ideas
Remove card go to setup scroll until you get delete all images;select;up or down button to change no to yes;select..turn off and try card again.Have to delete internal memory to use SD card.
Sep 17, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I started taking pics on my daughter's birthday function.. at the end of the function, my friend tried to take the camera from me but unforturnately it fell down. But we continued take pics and but after...
Try repeatly turning on and off the unit by removing the battery each time the lens error screen pops up...that worked for me this summer when mine S210 got jammed with a sand particle. The next level is to get access to the front cover. That requires more knowledgethan I'm currently aware of as I've only removed the back cover and the LCD retainer plate. Tomorrow I'm going after the front cover and I'll let you know if I'm successful. The entire camera seems to be accessible with a small phillips head screwdriver and a lot of patience. Taking apart an S210 requires great peace of mind...don't go in until you're in a good space...
Sep 27, 2010 | Nikon Coolpix S210 Digital Camera
Turn camera off and on again -- fried in outlet
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa.
May 22, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
When I take a pic, there is a delay in the time
There could be several problems like: 1)the focus 2)Self timer set to 2sec or 10sec 3)very slow shutter speed set
Make it as a 10 or 20 second delay on the self timer .Your problem here could be that the settings are not right. Go to the menus and reset all to original or default. Then set menus the way you like. You may have a slow memory card, try changing to a faster card, and test it.
Thank you!
May 17, 2010 | Nikon COOLPIX S200 Digital Camera
SD600 stuck in Video Recording mode
This worked for me. Take out battery and card. Wait a few minutes. Set camera in Auto (stil pic) mode. Replace card and battery, turn on. Select function, tab through all options returning to auto. Press function. This seems to be working, Let me know how this works for you. I found nothing on the Canon site. A sad commentary on the company.
May 31, 2009 | Canon PowerShot SD600 Digital Camera
Lense stuck out and can't take pictures
In all probabilities, the lens barrel must have tilted, preventing the lens from retracting into the barrel. It could also be possible that some dust particles got stuck in between the segments of the lens barrel. Check for these. Try to straighten the barrel without using much force, and try to remove any dust particle that got stuck between the segments.
Jan 14, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Camedia C-5050 zoom won't take pics
Is your memory full? Does the camera attampt to focus when you push the button down 1/2 way? If not the mode dial may be faulty (you are not in picture taking mode) or the shutter button may be faulty (no focus attempt) Try to use the timer button to get the shutter to trip.
Jul 10, 2008 | Olympus Camedia C-5050 Zoom Digital Camera
Cannon a410
are you on auto mode or manual? if you are on manual, your settings might be on macro mode. reset it to manual.
Dec 04, 2007 | Canon PowerShot A410 Digital Camera
Pics not clear
first have you changed the batteries, next go into your menu and put everything back to reset the any changes that you have made or better known at default. Good luck. Let me know if this is helpfull
Dec 03, 2007 | Canon Digital Rebel XT / EOS 350D Digital...
Canon PowerShot S2 IS Digital Camera Logo
769 people viewed this question
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
