I have a 2nd hand dishwasher.
I've cleaned the machine according to the operating manual; filled it with salt and rinse aid; matched the salt level with local water hardness and tried it; checked the hoses; checked the inlet filter and supply. Inevitably, there are some problems:-
1. Often (but not always) the machine fails to fill up. It completes the cycle including drying) but there is no evidence of any water being involved (An upright cup left in the machine remains empty)
2. The detergent compartment mostly fails to open. I've checked the solenoid and it works just fine. It may be linked to failure to fill with water.
Looking through various posts it seems this might be a sticking float valve but I cannot find out how to access the float value. There is a raised section in the middle of the floor of the washer which looks to be the right height to have water trickle in and trip a float to stop the machine filling. However, I cannot see how to get the top off check and if necessary free up the float.
Thanks for any advice on this or any other possible cause of the problem
Click on this link directly to check out how fill valve looks
http://www.applianceaid.com/images/fillvalve.JPG
you will have to remove the access panels to reach the fill valve click on this link to get more instructions
http://www.applianceaid.com/dishaccess.html
This is often the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
also click on this link directly to get all types of troubleshooting instructions
http://www.applianceaid.com/dish.html
This will help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya.
The fill valve is where the water supply hose is attached to your washer.
The reason for Failure to fill the water is Either of these :-
Water-inlet valve
The
water-inlet valve lets water enter the machine. If this valve is
defective, you need to completely replace it. It's usually located
behind the lower access panel on the left or right side. It's the
device with the main water line (usually copper) from the house, a
rubber tube to the dishwasher, and two wires attached to it.
Float switch
The
float switch is a small electrical switch that's located right below
the dishwasher "floor." Above the switch, on the inside of the
dishwasher, is a plastic cylinder that floats up as water fills the
dishwasher. If this switch is defective, or if the plastic float gets
caught or trapped in the raised position, the water can't enter the
dishwasher. If the float switch is defective, you need to replace it.
Now, regarding your second issue, Detergent Cup didn't Open, there might be other reasons as well. 3 of them are :-
Timer
On
many dishwashers, a plastic actuator arm mechanically links the timer
to the detergent cup. When the timer reaches the proper time in the
cycle, the timer activates a lever that opens the detergent cup. If the
linkage is broken or defective, the cup stays closed after you've
closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor
A
bi-metal switch is a simple electrical device that deforms when
electricity is applied to it. The degree of this deformation can be
engineered to concise standards.
The
timer energizes the bi-metal switch inside your dishwasher
door--directly behind the detergent cup--when the detergent cup should
open. When energized, the bi-metal switch deforms away from the
detergent cup latch, which opens the detergent cup. If the bi-metal
switch is defective, it may not deform enough to open the cup. If that
happens, you need to replace it.
On
some dishwashers, the bimetal switch is wired through the heating
element or motor circuit. If the element is broken (or open), or if the
motor is drawing low current because of a low-fill situation, the
bi-metal switch doesn't open properly.
Newer
dishwasher models use a wax motor instead of a bi-metal switch. It's a
sealed unit with wax that heats up and pushes a piston through to open
the door. The wax motor, controlled by the timer, mechanically opens
the door.
Detergent cup, itself
The
detergent cup itself can become clogged with old dried detergent that
prevents it from opening. Sometimes just cleaning the cup takes care of
the problem. If not, you probably need to replace the entire cup
assembly.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Hi, I started to answer this question to hep you and was cut off? Was almost done. Lets do this again. You need to get to the back of this unit and where the water lines come in, you need to turn off the water under the sink. Remove the line at the D. washer, and there should be a screen that collects water deposits, sediment and so on.I have seen the plugged solid. You can also check to see if the fill solenoid is working as this is it, where the water line connects.Keep your hand on it through the fill cycle to see if it stays on. If it shuts off way to soon, replace it. They do go out often.You say you checked the inlet filter? If the solenoid shuts of to soon, replace it. I would pull it anyway, to see what may be jammed inside it.The soap cup sounds like old soap around the mechanism.Try cleaning it by removing the front panel.I hope this solves you're problems or gives you some more direction to go in.Keep me posted, Sincerely,
Shastalaker7
This sounds like the fill valve. You can test the fill valve coil for continuity with a ohm meter, no needle movement = bad fill valve. You can also test the fill valve for 120 volts at the fill valve with a volt meter, power there and no fill = bad fill valve. No 120 volts there, you will have to trace power back to find the trouble maker. Test things like the float and float switch, wires and timer. Fill valves are very bad for working once or twice and then quitting, if your dishwasher fills the first and second fill cycles and then no more water through the rest of the cycle, replace the fill valve. You will need to remove the access panels to get at the fill valve. Dishwasher fill valves also have a screen built into the valve entrance, this can also get all clogged up and need to be cleaned.
Any questions ask.
Hi
When the Dishwasher won't fill you'll need to
check for the water inlet hose, the water inlet valve and the float switch
assembly. When the water fills your dishwasher, a float rises along with it. As
the float reaches a certain threshold level, it shuts off the flow of water,
thereby preventing a leak. Sometimes the float can get stuck in the wrong
position in your dishwasher, and it can prevent your dishwasher from filling.
Sometimes it can happen due to float valve and on other occasions due to float
switch. Inspect the water hose coming to the dishwasher for any blockages. If the
hose is not clogged then check the water inlet valve for any clogs, if the
water will not even fill for few seconds then certainly the water inlet valve
is bad and should be replaced. You can also use a multimeter to check
continuity on inlet valve. If you don't get any value on the multimeter then
you'll need to replace the water inlet valve assembly. However, if the valve is
fine then the float switch assembly should be replaced. Hope this helps...
Please post back if you need more information.
Daniel
Hi RogrRabbit
Thanks for the thought. So I poked about a bit but it seems quite hard to get at the fill valve. And I thought it might also be the AquaStop inlet valve. So I set the program to Universal and 'had another go'
And water entered the machine correctly (level seems a little low but I can try the adjustment)
I'll try again when it finishes its cycle and see if it still works
Does this invalidate the fill valve suggestion or otherwise change your view on what it might be?
Thanks for your advice.
OK so I tried again and this time got no fill at all.
So your diagnosis of a faulty fill valve sounds possible. Given that the valve works intermittently, how can I confirm this?
I presume I need to remove the access panels, start the machine, wait for the fault and then test for voltage and for continuity through the valve?
TFAI
How would I recognise the fill valve to test it?
Sorry to hear about the glitch - nothing to do with me I suspect. Mostly I type into notepad and paste just in case!!
I start an economy wash cycle and I can see water entering the flat plastic container inside the RH panel. The right quantity of water is pumped in, the wash cycle completes satisfactorily and the water is pumped out. This seems to suggest that all valves, filters etc can work properly (which I think rules out blockages).
Then it gets to the interim rinse cycle and no water is taken in. I can see water in the clear flat plastic container but it doesnt move. Also the DW makes a rather unpleasant noice - bit like a rusty hinge being opened but not as high pitched.
Also no water is taken in on the final rinse cycle
If I then go back to try a wash (as at the beginning) and repeat the wash, no water is taken in.
Its almost as if moving the DW around frees up something and then it works once and sticks
Any thoughts?
PS I am now away until Monday evening (30th) so will be unable to report anything until Tuesday
Then apologies - I did not know I had given you a bad review. Certainly not meant.
And I have no idea how to change it?! or even provide "2 thumbs up" whatever that is.
As you can see, I have added a few comment.
Recently: I start an economy wash cycle and I can see water entering the flat plastic container inside the RH panel. The right quantity of water is pumped in, the wash cycle completes satisfactorily and the water is pumped out. This seems to suggest that all valves, filters etc can work properly (which I think rules out blockages).
Then it gets to the interim rinse cycle and no water is taken in. I can see water in the clear flat plastic container but it doesn't move. Also the DW makes a rather unpleasant noice - bit like a rusty hinge being opened but not as high pitched.
Any thoughts?
PS How would I recognise a "fill valve" in order to test it?
PPS I am now away until Monday evening (30th) so will be unable to report anything until Tuesday
OK - so I have tried and failed to find the "fill valve".
Looking at the operation of the machine, water intake is controlled initially by an 'aquastop' valve (grey electrically powered box sited in the inlet pipe) and I suspect this is what others have called the 'fill valve'.
Water then flows into a slim clear plastic container on the RH side of the machine where there are various offtake points.
There is also a 'pressure switch' which is linked by a rubber tube to the bottom of the area that holds water. This switch appears to work (you blow in it and it goes click and the contacts change from closed to open circuit)
Amazingly it seems that if you tip the machine forward onto its front door and then straighten it up, it will fill OK. If I do NOT do this between the wash and the first rinse, it does NOT fill with water. When I did it between the wash and the first rinse, it did fill with water.
Bizzarre or what?!
Any suggestions
Looking at
There
open circuit)
Bizzarre or what?!
Any suggestions ?
PS Soap cup seems to have gone away
Hi charlymonty
A really great set of links - thanks
However: My dishwasher is a Miele and does not have a float of the sort pictured and I cannot find anything similar (see earlier description). There must be a switch somewhere that tells the machine when it has enough water but I cant find it. This is irritating as the fact that I can make it fill by tilting it suggest to me some phisical sticking of a valve somewhere
Nor does it have a fill valve as described. Filling is controled by this grey box in the inlet line and it works fine - when it works.
Any suggestions as to the location of a float switch (or its equivalent) on a Miele G 660?
PS I'd love to rate the info you provided highly but I can see how to do that as it didn't fix the problem?
SOLVED
Finally found it
It seems that the connector joining the wire from the aquastop valve (what I think others call the Fill Valve) to the rest of the electrics was loose/faulty. Fiddling around in that area, plugging, unplugging the connector, and a bit of bending of the contacts and everything now works fine.
Thanks to all those that participated.
The solution was most helpful and, while not exactly right, pointed me in the right direction and allowed me to correct the fault
The solution was most helpful and, while not exactly right, pointed me in the right direction and allowed me to correct the fault,
See my last post for more detail.
Hello Rincewindwiz, I have the same problem on the same dishwasher. However your solution doesn’t seem to work. Did you do anything else? Thanks a lot!
