Unplug washer, remove bottom front cover, (three phillips head screws at the bottom) unscrew filter and pull out (lower right). Next, remove the very smelly $2.67 in change and a nest of muck. Put every thing back together in reverse order
LOL!!! I had $2.71, a key, a pencil, 3 hair pins, a push pin, and a button!!!! Along with a wad of stinky, slimy hair and lint. Thanks, this helped a lot!!!! I love my front end loaders!!!
thank you so much. you saved me a service call. I had $2.92 in change, a 1$ dollar bill, a pin, 5 screws and a key.
The pump may be blocked up check drain hose to pump does it fell with water and does it rinse
My front loading washer will not turn the drum, water will run in and pump up but there is no movement from the drum.
