Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ghost on the screen, blue in color
Ghost still on the screen, blue in color have changed the convergence chips, changed 5 convergence resisters(discolored)
Sonny Berry
Level 3:
  • Sony Master 8,617 Answers
  • Posted on Nov 24, 2009
Sonny Berry
Sony Master
Level 3:
Answers
8617
Questions
Helped
1721867
Points
23750
Did you check the six 3.15 amp pico fuses on the D board in line with the resistors and the two 5 amp picos on the G board? Usually one or more of the Picos will blow especially on the G board
1helpful
Color is distorted. Green, red, and blue ghosts
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
2helpful
Picture color ghosting
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
3helpful
2answers
Blue shadow
  • Screen looks 3D
0667c5f.pngSOLUTION
Can I rectify the problems below, #'s+letters"r"doubled(ghosting)
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
1helpful
2answers
Hitachi TV, has red ghost lines outlining image on screen! Help!
  • Screen looks 3D
I have the ghost look, top and bottom of the screen is narrow
  • Screen looks 3D
Ghosting
  • Screen looks 3D
3helpful
Sony projection TV colors out of alignment
Solution:
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
>>>Solution<<<<
They have put together a kit for your exact model. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
1helpful
We have blue ghosts with brilliant colors
This sounds like the most common thing that fails on projection TV's, regardless of the brand. The convergence circuit has two STK392-110 IC chips mounted on heat sinks to drive the convergence yokes. They typically last anywhere from 5-10 years, then they fail. A more robust part is now available (STK392-150) as a direct drop-in replacement. My shop has installed these IC's in hundreds of projection sets and had fewer than 1% of them come back with repeat failures. Also check the following low-ohm feedback resistors to make sure they did not go out of tolerance:
  • RK42: 2.7
  • RK46: 2.2
  • RK58: 3.9
  • RK52: 3.3
  • RK50: 3.3
  • RK54: 2.2
2helpful
2answers
GREEN GHOST
If you want to adjust focus and screen there is a focus block some sets they can be found on the front behind the gril then behind a cut out held in place by screws if not check from the rear. But a ghost like you say sounds like a convergence problem
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
