Use Regeasy Cleaner(15-day trial) or Registry Easy 5.6 for
Windows(15-day trial) to clean the errors & invalid entries cause
system slow, freezing and crashing, and repair registry problems to
speedup your computer performances. Download it at following links:
http://www.versionhunter.com/windows/System/System_Miscellaneous/regeasy-cleaner.html
http://www.versionhunter.com/windows/Tweak/Registry_Tweak/registry-easy-56-for-windows.html
You may have to do a restore on your pc, Playing with the registry is dodgy business and you will probably do more harm than good. However that said you could try and doing a Backup of your registry then there are some pretty good applets out there that will scan your registry for you and check for errors. But if you are not comfortable with what a registry entry is or relates to then please do not try this. restoer it or take it to your local retailer
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
I use a free programme called cc cleaner that seems to work quite well you can download from herehttp://www.ccleaner.com/ just instaqll it and run registry cleaner and fix all issues see if it works
