SOURCE: p42vca30eh
hi good morning
try rmaccessories
the remotes are £12.99 and free postage
e mail them at
sales@[email protected]
SOURCE: Stuck on Standby, Fujitsu Plasmavision: Model pds4229e-b
I had exactly the same problem with a Fujitsu General PDS4208E. After looking at the forums etc bit the bullet and tracked down an ORIGINAL remote. Paid yesterday, arrived today - batteries in...screen back on!! One proviso here: Before you pay big money for an original remote (and ONLY they will work with these 2nd generation plasma screens not universal remotes) make sure that your screen WAS working before it was in the standby mode. try http://www.portables.co.uk/ on +44 208 968 1444. Ask for Andy. He seemed to know what he was talking about. About £50 +VAT plus next day delivery charge. Alternatively borrow mine at £5 a button press!! ;-))
SOURCE: How do you connect a fujitsu p42vca30eh to a BT
You should use a HDMI cable. This cable will carry the audio and video from your Vision box to your plasma screen. Connect the cable to the HDMI port on the vision box and the other end to HDMI 1 on your TV. Once that is done turn on the vision box and then the TV and switch the TV to HDMI 1 using your tv remote and then once you have a picture use your vision box remote to change channels and perform other functions.
Assuming the power supply is exact replacement and you did not have this before--check the speakers to make sure not turned off.
If using a cable or sat box make sure sound not way down or off both with the set and the box.
Last but not least if sound is there with a DVD---something somewhere is set to wrong position.
The power on button is usually under the front right edge of the screen. How did the screen get into standby mode? If it was a universal remote then you need to input the exact same code and try a variety of buttons to get it to power up.
Hi himsbarry, did you get this resolved?
I bought a 'One for All' universal remote for my fujitsu PS4208e screen. (Richer Sounds £14.99) Started the scan for the right code...and it sent my screen into standby, and I cannot get it to power on again.
Sending a signal to the inputs doesn't seem to trigger it either.
Has anyone tried the RS232 connection?
cheers
