Question about Rival CF250 Deep Fryer
Hello - i have lost the cordset of this deep fryer
Hello
i have lost the deep fryer cord can u pls assist me in getting a new one iwant mdp-1 cordset for the below mentioned model
any help provided will be greatly appreciated
thanks
Posted by s_waheeda on
Bud Pytko
    New Friend:
  • 18 Answers
Contact Rival at the below link....
https://secure.rivalproducts.com/ContactUs.aspx
Posted on Nov 24, 2009
Need a plug for my Rival Deep fryer - the mdp-1 cordset
i have that same deep fryer, rivals web site sells any part you need
Oct 19, 2010 | Rival RCF25 Deep Fryer
Cordset
You can find replacement cords for many counter top appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the corect cord.
May 05, 2010 | Cook's Essentials CEDF202T Deep Fryer
Looking for a dp 16 cordset
appliances at most appliance and building supply stores. Try Ace, Home Depot, Lowes. Take the cooker with you to make sure you are getting the correct cord.
Aug 25, 2009 | GE 168952 Deep Fryer
I need to purchase the power cord with magnetic plug for my deep fryer. GE cannot help me with this part? Where can I find a new power cord?
If it is a DP16 cord, good luck with finding a new one, but if you still have the old one, the following might help,
Solution for fixing DP16 Cordset for GE deep fryers: To begin with, you willl need to clean the electrical contacts on both the fryer and the cordset. They will be burnt from electricity arcing between the two when the cord is plugged into an outlet before connecting to the deep fryer. I used a dremel tool attachement grinder used for sharpening chain saw chains. It is cylindrical and fits in the holes in the cordset perfectly. You could use sandpaper rolled into a small cylinder, or whatever is available that will do the job. To open the flaps that cover the holes, insert a toothpick in the center hole of the cordset while you work. Make sure that both sets of contacts are completely clean before proceeding with the next step. Next, using needle nose plyers, make two tight coils of fine or extra fine (.032") resin core solder the same size as the holes in the cordeset. Press into place in each of the holes in the cordset against the electrical contacts. Spread the coils a little so they cannot fall out when the cordset is not attached to the fryer because the flaps will likely not close properly or at all. You can work the coils down so the flaps will close if you use the .032 solder, but they will still be a little loose, so they might jam the flaps open or partially open. This definitly isn't a UL approved method, but it will fix the problem completely. Happy frying!
Aug 06, 2009 | GE Kitchen Appliances - Others
Have rival deep fryer MDP-1. Need the cordset for this product.
yes! through thier webiste or through Sears.com parts
Dec 07, 2008 | Rival RCF25 Deep Fryer
Rival deep fryer
www.rivalproducts.com is the website, but I can not even find replacement cords on the site. Good luck!
Mar 28, 2008 | Rival RCF25 Deep Fryer
Cord
call 1-800-323-9519,Just got mine in the mail today and it works perfectly.The total (sh/handling) was 12.75.ask for the MPD-1 cord set. The letters are switched around,but its the same cord.
Jan 27, 2008 | Rival CF250 Deep Fryer
GE 106789 Cool Touch Deep Fryer
called Rival,they have loads of MDP-1 power cords sets,just purchased mine today.(1800-323-9519).BTW,,When asking ,its listed as MPD-1 instead of MDP-1,(typo error).Its the same cord.
Jun 17, 2007 | GE 106789 Deep Fryer
Rival CF250 Deep Fryer Logo
279 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
