Question about Extended Systems Pocket Print Server
My network HP laserjet 4Vprinter and ESI 2830 pocket print server suddenly gives an error message "No RARP/BootP Server". How can I fix this?
  • 3,741 Answers
Try Disconnecting and reconnecting cables. Changing cables and pocket print server. if that does not helps your system needs reconfiguration just click this link directly http://docs.sun.com/app/docs/doc/806-3323/6jcfsj369?a=view
This will help. Thanks please keep updated. please dorate the solution positively .thank you for using fixya.
Posted on Nov 24, 2009
    Genius:
  • 1,689 Answers
The information in the link is too long to paste but you may want to look at it.
HP Jetdirect and Embedded Jetdirect Inside Print Servers - TCP/IP, Messages on Configuration Page or Self-Test Page
Get the IP address subnet and gateway address of a computer in the same network.
Usingthe LJ5's control panel, setup a static IP for the Jet Direct using thenumbers you got from the Laptop, except change the last number of theIP to one that is not being currently being used. Perhaps adding 5 or10 to the highest number in use.
Here are the steps to configure the LJ5.
1.Press MENU, repeatedly, until the following message appears on thecontrol panel: HP LaserJet 5/5n/5m and the original Color LaserJet: HPMIO MENU
2. Press ITEM. CFG NETWORK=NO* will appear.
3. Press the PLUS button once. CFG NETWORK=YES* will appear.
4. Press ENTER or SELECT.
5. Press ITEM repeatedly until CFG TCP/IP=NO* appears.
6. Press the PLUS button. CFG TCP/IP=YES* will appear.
7. Press ENTER or SELECT.
8. Press ITEM until BOOTP=YES* appears.
9. Press the PLUS button. BOOTP=NO will appear.
o When using BootP or DHCP, keep the setting BOOTP=YES*.
o The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect.
o No other TCP/IP configuring is necessary.
10. Press ENTER or SELECT.
11. Press ITEM. IP BYTE 1 = (value) will appear.
12.Press the PLUS button until the value of the first byte of the IPaddress appears on the control-panel display. By pressing SHIFT and thePLUS button, the value will decrease.
13. Press ENTER or SELECT.
14. Press ITEM to continue. Repeat Steps 11-13 to configure the remaining bytes of the IP address.
15.Repeat Steps 11-13 to configure the subnet mask bytes (SM BYTE 1=),syslog server IP address (LG BYTE 1=), default gateway (GW BYTE 1=),and timeout (TIMEOUT=).
16. Press ONLINE. Print a self-test page to verify the IP settings.
17. If the test page does not show the correct settings, power cycle the printer and reprint the test page.
else: have the printserver reinstalled
www.nls.com/common/pdfs/v307n10.pdf
6ya staff
SOURCE:
Jetdirect ex default ip
Usually it it set to pick up IP from DHCP/BootP.
If someone had assigned a fixed IP and it is now unknown. It is better to reset the print server to factory default by pushing the little reset button,
Then check you DHCP server for the newly assigned IP address.
You will need a version of HP Jetadmin or HP webjetadmin to configure this print server
May 13, 2014 | HP JetDirect EX Plus Print Server
I have hp laserjet 3035 but when i configure send to email,.,.,i already input smtp etc ,so when test they give a reply with valid input,.,.,but when i try to send email they have an error executing...
I Would suggest you have the printer self configure ( eg have the printer boot up when connected to the network with bootp/auto ip selected as my net connection , this will automatically input the available server addresses , when this has completed then i would manually re configure to better suit My needs as to what address is used for communication.
alternatively you can using the CMD function and Ping/ ipconfig commands in dos window to find the Ip credentials of the server for manual input into printer
Mar 04, 2014 | HP LaserJet M3035 MFP Printer
Reset ESI 2833 until red light turned green. Network Printer still not responding
Check the IP Address of the 2833. I believe there is a gray button you can depress to print out a configuration sheet. If the wireless modem was also your router, you may have a different IP address range and will need to set the 2833 accordingly.
Sep 03, 2013 | Extended Systems Pocket Print Server
How do i enter service mode
Use DHCP : Off Use BOOTP : Off Use RARP : Off Enable DNS Dynamic Update : On Use Zeroconf Function : On IP Address : 192.168.1.20 Subnet Mask : 255.255.255.0 Gateway Address : 192.168.1.1 LPD Printing : On IPP Printing : On IPP Printer URI : printer RAW Printing : On Raw Port Number : 9100 RAW Mode Bi-direction : Off FTP Printing : On Primary DNS Server Address : 0.0.0.0 Secondary DNS Server Address : 0.0.0.0 DNS Host Name : NB-17FB0000859B9287 DNS Domain Name : Multicast DNS Service Name : Canon iPF710 (9B9287)
Nov 21, 2012 | Canon imagePROGRAF IPF605 Printer
I would know if D-Link DP 301P Print Server supports SNMP protocol because i need to print from IBM iseries thank you
It supports all below protocol so you can give print from IBM iseries .
TCP/IP Protocols Supported :
  • BOOTP
  • SNMP
  • Telnet
  • TFTP
  • FTP
  • LPD
  • RARP
  • DHCP
Jul 28, 2009 | D-Link DP 301P (DP-301P) Print Server
Installing hp laserjet 4100dtn over the network using tcp/ip addr
Hi admin30:
Here is some info for you.
EIO menu (networked printers)
The EIO (enhanced input/output) menu appears only when an EIO device is installed in an EIO slot
on the printer (such as an HP JetDirect print server). The items in the menu depend on the particular
accessory product installed. If the printer contains an HP JetDirect print server EIO card, you can
configure basic networking parameters using the EIO menu. These and other parameters can also
be configured through HP Web JetAdmin.
Table 27. EIO menu
Item Values Explanation
CFG NETWORK=NO NO
YES
Select whether or not you want to use
the HP JetDirect menu.
NO: Bypass the HP JetDirect menu.
YES: Use the HP JetDirect menu. You
must change this to YES each time you
want to use the menu.
Note
You must select CFG NETWORK=YES to
display the following items.
IPX/SPX=ON ON
OFF
Select whether the IPX/SPX protocol
stack (in Novell NetWare networks, for
example) is enabled (ON) or disabled
(OFF).
DLC/LLC=ON ON
OFF
Select whether the DLC/LLC protocol
stack is enabled (ON) or disabled (OFF).
TCP/IP=ON ON
OFF
Select whether the TCP/IP protocol
ATALK=ON ON
OFF
FG IPX/SPX=NO NO
YES
Select whether you want to use the IPX/
SPX menu and set IPX/SPX protocol
parameters.
NO: Bypass the IPX/SPX menu items.
YES: Use the IPX/SPX menu items.
In the IPX/SPX menu, you can specify
the frame-type parameter used on your
network.
The default is AUTO, to automatically set
and limit the frame type to the first one
detected.
For Ethernet cards, frame type
selections are EN_8023, EN_II,
EN_8022, EN_SNAP.
For Token Ring cards, frame type
selections include TR_8022, TR_SNAP.
In the IPX/SPX menu for Token Ring
cards, you can also specify NetWare
Source Routing parameters, which are
SRC RT=AUTO (default), OFF, SINGLE R, or
ALL RT.
CFG TCP/IP=NO NO
YES
TCP/IP menu and set TCP/IP protocol
parameters.
NO: Bypass the TCP/IP menu items.
YES: Use the TCP/IP menu items.
In the TCP/IP menu, you can specify
BOOTP=YES or DHCP=YES for TCP/IP
parameters to be automatically loaded
from a bootP or DHCP server when the
printer is turned on.
If you specify BOOTP=NO and DHCP=NO, you
can manually set the following TCP/IP
parameters from the control panel: each
byte of the IP address (IP), Subnet Mask
(SM), Syslog Server (LG), and Default
Gateway (GW). You can also manually
set the idle timeout period.
Print an HP JetDirect configuration page
to verify your settings. However, note that
the print server might overwrite selected
parameters with values that ensure
proper operation.
Table 27. EIO menu (continued)
Select whether the Apple EtherTalk
protocol stack is enabled (ON) or disabled
(OFF).
May 26, 2009 | HP LaserJet 4100dtn Printer
Configure tcp ip hp 750c
Assuming the JetDirect card is installed and properly functioning, use the following. Also, you may have to update the rom on the I/O Card to the latest version.
  1. From the front control panel message, Ready or Ready to Plot, press ENTER.
  2. Press the Up arrow key until I/O Setup appears, and then press ENTER.
  3. Press the Up arrow key until Modular appears, and then press ENTER.
  4. From the front control panel message, Cfg Network=No, press ENTER.
  5. Press the Up arrow key to change to Yes, and then press ENTER.
  6. Using the Arrow keys, scroll to Cfg TCP/IP=No appears, and then press ENTER.
  7. Scroll to Yes, and press ENTER.
  8. Press the Up arrow key until BootP=Yes appears, and press ENTER.
  9. Press the Up arrow key to change to No. Press ENTER (When using BootP or DHCP, keep the setting BOOTP = YES *. The BootP or DHCP server will configure the TCP/IP parameters on the HP Jetdirect. No other TCP/IP configuring is necessary.
  10. Press the UP arrow once to get to the IP byte section.
  11. To change the IP byte, proceed as follows:
    1. Press ENTER.
    2. Press the Up or Down arrow key to change the number.
    3. Press ENTER.
    4. Press the Up key to continue to IP Byte2=xxx.
    5. Press ENTER.
  12. Configure the remaining bytes of the IP address in the same manner. A valid IP address is required for proper operation.
  13. Configure the subnet mask bytes (SM), syslog server IP address (LG), default gateway (GW), and timeout (TIMEOUT) by pressing the ENTER and the Up or Down arrows in the same manner as above. The timeout parameter default is 90 seconds. Up to 3,600 seconds can be configured. If set to zero, the timeout feature of the HP Jetdirect print server is disabled; TCP/IP connections will remain open until closed by the server.
  14. Press PREVIOUS repeatedly, until the Ready to Plot or Ready message appears. Refer to the HP Jetdirect Network Interface Configuration Guide to configure the network operating system.
  15. Press the Up and Down arrow keys simultaneously to save the IP address on a 750/755 plotter. (A page should print and the IP addresses will be saved.)
Nov 19, 2008 | HP Jetdirect J2552A/B (J2552AB) Print...
LexMArk Marknet 700Oe: Booting problem
hmmm...ok..you'll need to reinstall the server software, where those reside..
Jun 15, 2008 | Lexmark MarkNet N7000e (1 USB port) 10/100...
Printing problem "PCL XL error"
PCL XL ERROR subsystem: Kernel Error: Illegal Tag Operator :0 x 1b Position: 6
Apr 12, 2008 | HP LaserJet 3030 All-In-One Printer
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Extended Systems Pocket Print Server Logo
553 people viewed this question
Top Extended Systems Computers & Internet Experts
Ekse
Marvin
Marvin
Are you an Extended Systems Computer and Internet Expert? Answer questions, earn points and help others
