I have a zanussi washing machine mod I have a problem i found a wash i had done was still soaking wet after the program had finished so i put it on spine cycle only and nothing happened. so i tried a different program and it srarted to work but did not commplete the full progrem so i had to manualy drain the water. could you please advise me.Thank's
Genius:
Washing Mach... Master
Re:
If the drum is not turning this could be due to worn motor brushes,assumimg that its pumping out the filter will be clear and spin should follow @ program end.The motor brushes are secured by two screws each.....
i know the bolt you mean and i find it is impossible to shift zanussi issued a bulletin saying to give it a good blow with a hammer to break the loctite that is used. i never found this works. the only way i found of doing it was to heat with a needle flame from the oxy/butane burner i kept for fridge work
