ERROR codes Canon 6045
Canon 6045 E000 Fuser did not heat up. Lamp, thermal switch, thermistors, connections, AC driver, DC controller, SSR, etc. E001 Fuser temperature too high. Same possibilities as E000, as well as shorted wire. E002 Fuser temperature not rising at correct pace, same possibilities as E000. E003 Fuser temperature drops. Same as E000. E004 Fuser problem: AC driver, SSR bad, wire shorted. E005 Fuser cleaning web, or problem with sensor, lever or connector. Service mode 6 is the probably reset for this. E006 Fuser feed connector. E010 Drive problem. Main motor, gears, etc. E013 Waste toner drive problem, or waste toner sensor switch has been actuated too many times. E015 Pickup motor power supply. Could be bad motor or motor board, or DC controller. E020 Problem with developer unit, toner hopper, hopper motor, connection, sensor or DC controller. E030 Total counter. E031 Option counter or total counter. E050 Holding tray (duplex) home position sensor motor or board. E051 Holding tray (duplex) home sensor motor or board. E202 Panel locked up, but might be no code, scan motor problem. E203 Scan problem or scan sensor E204 Scan problem or scan sensor E210 Lens sensor or motor problem E212 Lens sensor or motor problem E213 Scan lock sensor or lock solenoid E220 Exposure lamp regulator board E240 DC controller or composite power supply problem. E243 DC controller E400 RDF to copier communication problem E401 RDF pickup motor or pickup sensor. E402 RDF belt motor or pulse sensor. E403 RDF feed motor or pulse sensor. E411 RDF tray sensor or registration sensor E500 Sorter main board or communication with copier E510 Sorter feed motorE522 Sorter push bar motor E523 Sorter reference wall motor E524 Sorter multi-guide motor E525 Sorter bin paper sensor automatic adjustment problem E526 Sorter bin paper sensor automatic adjustment problem E530 Sorter guide bar motor E531 Sorter stapler motor E532 Stapler motor E533 Stapler inside paper sensor E540 Sorter bin shift motor E550 Sorter power supply E710 DC controller E711 DC controller E712 Document feeder IC failure E713 DC controller, sorter E800 Auto power off circuit problem. Main switch or DC controller. E802 Auto power off circuit problem. Main switch or DC controller.
Checked delivery tray detection sw103 @ j85 pins 1&2 the switch & wire to the dc controler are good.
