My understanding of this printer is that to print it requires all cartidges to be installed, not just a black one.Any empty cartridges have to be raplaced, regardless
Thanks for using FIXYA
When you click file>print or whatever the steps are when the print window then pops up. That is where you select the number of copies etc. There should be a properties button to clicl. When you click that There will be a color tab. You click select print in greyscale and print with black cartridge only.
Thank you,
Lee
Look at the following chart :-
http://www.uktsupport.co.uk/canon/bj/bjc85.htm
Check the number of blinks and you would find the fix.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Note - Do accept the solution, if 100% satisfied from my service!!
You try to do a test print? Here you should get an error printing
It sounds like you only replaced the printer cartridge, not the printhead. However, since it sat for an extended period the print head mayneed replacement.
If you know of someone else that has a BJC-85 trytheir print head and see if that resolves the issue. You can buy boththe head and cartridge together, but the cost about $45.
Hope helped with this.
v
I suggest download Canon BJC-85 / BJ M70 service manual. This
service guide is a maintenance troubleshooting and instruction owner
manual reference used for maintaining and servicing thecanon BJC-85 / BJ M70 printer. It provides comprehensive information on identifying canon BJC-85 / BJ M70 printer features, components, and spare parts; troubleshooting printer problems and performing printer disassembly procedures.
Table of contents Canon BJC-85 / BJ M70 Service Manual (pass: printer1.blogspot.com )
1. PRODUCT OUTLINE
2. CHANGES FROM THE BJC-80/80v
3. EXTERNAL APPEARANCE
4. SPECIFICATIONS
4.1 PRINTER SPECIFICATIONS
4.2 INTERFACE SPECIFICATIONS
4.3 PAPER SPECIFICATIONS
4.4 PHOTO BJ CARTRIDGE SPECIFICATIONS
5. OPERATION
5-1. FUNCTION SETTING
5.2 ERROR INDICATIONS
5-3. INK LOW WARNING RESET BY BUTTON OPERATION
5-4. DIRECT PRINTING FUNCTION OF THE IMAGE FROM DIGITAL CAMERAS
6. SPECIAL TOOLS
7. PARTS LIST
8. CIRCUIT DIAGRAM
Success.
The red lighy (power) does not blink, the green light (error) does blink. For other lights error, review the mean about this codes in Canon BJC-85 codes
HERE you have all details about "printing with MAC" settings (page 145).
Also can try to download the manuals HERE
Good luck.
After clicking print, click on properties and go to the color screen and make sure it reads print in grayscale only
Hello Segurry,
To change the settings for your Cannon BJ printer, do this:
After making sure that it is connected to the system.
Click on start, then navigate/go to control panel,
When you get to control panel, look for Printers and Faxes and double-click on it.
Next, locate your printer there and right-click on it, then go to properties.
When you get to this properties pages, click on Device settings, then go to "Installed Print Catridges" and select the black-ink catridge.
You can also change other settings here to suite whatever your printing preferences are.
Kindly keep me posted about this problem and let me know how it goes after doing this.
Hope it helps.
Good luck
For that go to start menu ->control panel->Printer and faxes.
Then right click on your printer icon then click on property.
Then click on printing preferences .
Then click on paper quality.
There is 2 option select black and white then apply and ok.
Then check.
Also check in your printer menu settings that black and white is select in printer settings menu.
Let me know if you need further assistance.
Thanks for using FixYa.
THere is no property setting in the printers/faxes in the System preferences. I am using a macbook.
THere is no property setting under printers/faxes. I am using a macbook.
THere is no property choice uner printers/faxes in System preferences. I am using a macbook.
What do you mean print dialoge box? I don'y know what/where that is.
Where is the print dialogue box?
Sorry... still waiting.
These do not exist: presets standard select save as give new name and save.
You can find that settings in paper tray and quality.
Hi. Are you still with me?
HI, when I locate my printer in the control panet, the is no "properties" to select. I am using a macbook.
SInce I have a macbook, there is no right click and no properties.
This doesn't work. I have a macbook.
HI, As I said before, there is no option for "properties" I s it b/c I have am acbook?
After I click on print, there IS NOT PROPERTIES CHOICE....and when I click on PROPERTIES< There is no color screen choice.
I am still waiting for a response on the properties issue.
HI, So far no one has addressed the "properties" issue. I found Properties in the Word menu, but there is no color scale on it. THere's just General, Summary, Statistics, etc. No place to click on black ink only.
HOw does that relate to the settings question? I did only replace the cartridge but am not about to spend $45 if I don't know what the problem is! HOw do I do va test print?
NO, It didn't. I'd like some more suggestions.
I can't do a test print. Now the red "error" light is on the printer.
I have fixed the ink color problem. Now the paper is not being moved through the printer. I can hear some wheel s turning but the paper does not move. THen the error light comes on and I have determined that it means "paper jam", but there is no paper in the machine.
Now the orinter is not feeding the paperthrough.
