Garden Logo
Posted on Nov 24, 2009
How to mix the oil and gas for a 69dB(A) - John Deere Garden
Sivaranjini
Level 1:
  • Contributor 241 Answers
  • Posted on Nov 24, 2009
Sivaranjini
Contributor
Level 1:
Answers
241
Questions
Helped
127437
Points
31
Hi friend,
16:1 24:1 32:1 40:1 50:1 Litres millilitres of oil 5 300 200 150 125 100 10 625 425 300 250 200 15 950 625 475 375 300 20 1250 825 625 500 400 25 1550 1050 775 625 500 16:1 24:1 32:1 40:1 50:1 Imp Gal Imp ounces of oil 1 10.0 7.0 5.0 4.0 3.0 2 20.0 13.5 10.0 8.0 6.5 3 30.0 20.0 15.0 12.0 9.5 4 40.0 27.0 20.5 16.0 13.0 5 50.0 33.0 25.0 20.0 16.0
16:1 24:1 32:1 40:1 50:1 US Gal US ounces of oil 1 8.0 5.5 4.0 3.2 2.5 2 16.0 10.5 8.0 6.5 5.0 3 24.0 16.0 12.0 9.5 7.5 4 32.0 21.5 16.0 13.0 10.0 5 40.0 26.5 20.0 16.0 13.0 16:1 24:1 32:1 40:1 50:1 Litres US ounces of oil 5 10.5 7.0 5.5 4.0 3.5 10 21.0 14.0 10.5 8.5 7.0 15 32.0 21.0 16.0 12.5 10.0 20 42.5 28.0 21.0 17.0 13.5 25 53.0 35.0 26.5 21.0 17.0 16:1 24:1 32:1 40:1 50:1 US Gal millilitres of oil 1 225 150 125 100 75 2 475 325 225 200 150 3 700 475 350 275 225 4 950 625 475 375 300 5 1175 800 600 475 375 16:1 24:1 32:1 40:1 50:1 Imp Gal millilitres of oil 1 275 200 150 125 100 2 575 375 275 225 175 3 850 575 425 350 275 4 1125 750 575 450 375 5 1425 950 700 575 450 hope this helps u
please rate me...........................
thank u for using fixya
regards
sivaranjini
Have a poulan wild thing and the oil bar compartment has gas in it
I would drain the oil and gas or whatever is in it. I would also drain the 2 cycle mix from the gas tank and start with a fresh gas and oil mix and fresh bar oil. The mix for the Poulan Wildthing is a 40:1 mix.
You are definitely going to smell gas when using any chain saw.
2answers
What is troy built tb 32 EC gas oil mix ratio?
Hi anon, the usual ratio for most 2 stroke engines is 40:1. The 1 being two stroke oil
Jul 30, 2014 • Garden
What goes in a kdx 80 gear oil or 2 stroke oil
Engine oil goes in the gearbox/transmission. Two stroke oil (also know as pre-mix) is mixed with the gas and oil in a separate gas can (to thoroughly mix the pre-mix and gasoline) and then the mix is poured into the fuel tank.
Do I mix the oil and gas together and pour it in the gas tank or do I pour the gas in the tank and the waverunner mix's the oil and gas together?
Mix the oil and gas together first.
Or you can add some gas into tank, then add some oil, then add more gas, then bit more oil ... so oil-gas mixture is uniform.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 24, 2012 • Boating
2answers
What kind of gas
Regular unleaded gas mixed with 2 cycle oil. (You need to check your model for mixture ratio but 30:1 (thirty parts gas to one part oil mix) is usually a good place to start) You can find mixing instructions on the back of the 2 cycle oil container
Dec 08, 2010 • Garden
2answers
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 • Garden
1helpful
My B&S Yard Machine shoots out white smoke it also leaks out oil and gas mixed
If this is a 4 cycle mower (seperate places for gas and oil) and you are using a oil and gas mix as I am reading from your post that is your problem. When you use a gas&oil mix in a 4 cycle you get smoke and if fouls your spark plug. Also be more specific where the oil and gas mixed is leaking from. I SUGGEST THAT YOU DRAIN OUT THE GAS&OIL MIX AND CLEAN THE SPARK PLUG OR REPLACE AND FILL WITH STRAIGHT GAS AND SEE HOW IT RUNS.
Good luck
roundo4
4answers
I guess he needs to know what kind of oil he needs also
you shouldn't need to mix oil with gas on a four cycle engine. this is for two strokes.
Aug 23, 2009 • Garden
1helpful
11A-418A729 - straight gasoline or gas/oil mix
If it has an oil stick, it is sraight gas. No oil stick to check oil then, gas/oil mix needed.
Mike
4helpful
2answers
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 • Garden
Top John Deere Garden Experts
john h
Sean Wright
Sean Wright
Jay Finke
Jay Finke
Are you a John Deere Garden Expert? Answer questions, earn points and help others
