RCA D52W19 52" Rear Projection Television Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a RCA Home Theatre, gemstar guideplus gold. I think it is a 52" rear projection. I just want to know is it a HD TV?
  • patspath Nov 25, 2009
    ok, so let me ask this, if I hook up a Direct TV HD dvr, will I get a HD picture?
Anonymous
Level 3:
  • Master 647 Answers
  • Posted on Nov 24, 2009
Anonymous
Master
Level 3:
Answers
647
Questions
Helped
149847
Points
2098
It does not have an HD or ATSC tuner. But it does have HD resolution inputs - ie HDMI and component video (RGB) so effectively it is HD
  • Anonymous Nov 25, 2009
    Yes if you use the DVI-HDTV output from the from the DVR and hook it to the DVI-HDTV input of the TV
1helpful
RCA Guideplus gold gemstar analog or digital
Most of the RCA GuidePlus Gold gemstar TVs worked with analog TV signals (NTSC) only. The Guide+ information was only broadcast in NTSC signals and is no longer being provided. If you can check the date of manufacture of the TV, you can use the size to check if it had an ATSC tuner added if it was made for the US market. 37"+ TVs had to have a digital tuner in second half of 2005. 25" TVs needed to have the ATSC tuner after March, 2006. The next year all TVs had to have a digital tuner.
I hope this helps. Please add a comment with the model number of the TV, if you would like me to confirm the tuner information on your set.
(The RCA F31317 TV with Guide+ was manufactured in 2000 and thus only has a NTSC tuner.)
2helpful
I was just given a 36-inch RCA Gemstar Guideplus Gold TV. I do not have cable and am unable to tell if it is digital or not. I've been told it is less than 6 years old. It is a tube TV.
RCA made only two 36" televisions between 2004 - 2010 and neither one of them have digital (ATSC) tuners. They made ZERO CRT televisions before that with digital tuners.
I think my speakers are blown on my sony 53 inch rear projection tv can I run the sound through my home theatre and bypass the blown speakers?
check your audio menu on your tv. mine can turn off the speakers and sends the audio signal out the rca's when the speakers are off.
I have a proscan digital hi res television model number ps61810 guideplus gold gemstar it was manufactured in 2000 used maybe twice but cant find info on wiether or not is it high def can u help me
I AM LOOKING FOR THE CIRCUIT BOARD THAT IS BEHIND THE FRONT CLOTH COVER ON MY PROSCAN PS61810 THAT CONTROLS THE REMOTE,VOLUME AND CHANNELS ON IT. IF YOU KNOW WHERE I CAN LOCATE THIS PART OR PARTS PLEASE LET ME KNOW. THANK YOU FOR YOUR TIME. [email protected] - 915-309-7011
Instructions for rca gemstar guide plus universal remote
From: [email protected] Need code for home theatre guide plus gold gemstar 52.
2answers
Can anybody help me disable the Guide+ on my 52" RCA TV?
When you first turn your cable tv on go to the customer menu and turn off the G+, you should find it in your set-up section.
RCA Home Theatre Projection TV
Your ICs are bad that control the Convergence. I would quess that the ICs that they have used before have been the cheaper versions. Sanyo are the best the cheap ones only last for a while then need replacing. The sanyo chips cost considerably more than the imitation ones but are worth it in the long run.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
