Here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-2700R/index.html
Setting the clock
Use these instructions to set the clock.
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
select the segment of the clock display you
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
As you select segments of the clock display
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Cheers!
Posted on Feb 15, 2010
SOURCE: can't set the clock on my pioneer deh-6000 car
this is loads of fun....with the unit OFF, press and hold the FUNC button until the time and date appear on the display (one of the units on time or date will be blinking. Use the up/down/right/left control to change numbers and position....when satisfied with date and time, turn unit ON and your good to go.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_aad3edb7dfa380b9
Posted on Mar 10, 2009
SOURCE: dont know how to set the clock.
turn your unit off by pressing the SRC button. then press the clock button (clock appears). press the audio (or function button) and then the hour blinks. press up or down to change setting and left or right to switch from hours to minutes. press audio button. wallah!
Posted on Feb 23, 2007
SOURCE: SETTING CLOCK FOR PIONEER Deh p49001b' CD AM/FM/
shut it off then hold the function button
Posted on Dec 27, 2008
SOURCE: how do you set clock on pioneer wma/mp3 supertuner car tuner
Press function repeatedly until the clock appears in the display. Then use the left and right arrows to select hours or minutes. As you select the segment of the clock the selected segment will blink. Then press the up or down arrow to change the setting accordingly. Press function again to exit the clcok setting
http://caraudio.manualsonline.com/mdownloads/751a22f3-8f11-4855-a9fa-e2ec2056a118.pdf
Posted on Nov 26, 2009
SOURCE: I have a EEQ MOSFET
I have same problem.
Try this link for the manual (similar model)
http://www.pioneerelectronics.com/PUSA/Products/CarAudioVideo/In-Dash/CD-Players/DEH-P6500?tab=D
click on owners manual, half way down. Once its downloaded page 32 talks through clock settings. You have to switch the headunit off at the source button - Good Luck.
Posted on Sep 30, 2010
