Question about Hotpoint RFA60 Bottom Freezer Refrigerator
Pool of water forming at bottom of fridge since defrosting
Posted by squadge on
Anonymous
    New Friend:
There should be a narrow plastic funnel accross the back of the fridge. This may have mould and food particles in it. Wipe clean and get a length of fine "piano wire". Push this gently down the hole, twisting to get it past the bend. This probably leads to the top of the compresor tank where it normally flows and evaporates. When you find a piece of suitable wire, keep it for future use. hold
Posted on Nov 24, 2009
4 Related Answers
FreeTech
Lee N.
  • 426 Answers
SOURCE: water in the bottom of the refrigerator
this sounds like a clogged defrost drain remove cover and check drain tube for obstructions
Posted on Apr 04, 2010
Ishola Olayemi
  • 1196 Answers
SOURCE: Water collects at bottom of
The problem could be that the defrost timer is bad, A
mechanical defrost timer controls the defrost cycle of the freezer. In older models, the timer runs continuously and roughly every six hours, cuts power to the cooling system and sends power to the defrost heater. If the timer does not advance, the appliance will be stuck either in defrost or refrigerate mode, resulting in, respectively, no cooling or frost build-up.
The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. It may also be found behind a cover plate inside the refrigerator or freezer, in the temperature control console, or behind the refrigerator near the compressor.
To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced. If it advances as it should, then you can follow the steps below to test the switch electrically.
The timer is usually held in place with one or more screws. Remove the screws and gently pull the timer out far enough to disconnect the wiring connector. The connector can be removed by firmly pulling and rocking it left and right. It is not necessary to note the position of the wires because the connector plug is keyed so that it can be replaced in only one way. If it is bad, you will need to replace it to fix the problem.
Posted on Jul 26, 2011
Techsim
James
  • 59 Answers
SOURCE: Roper whirlpool model 2314273-A
This sounds like a defrost drain problem. Behind the panel in the back of freezer is a heater that defrosts the evaporator and below that is a drain hole. They will occasionally get clogged or just freeze over Pour hot water down it until it thaws then check to see if the water drains normally. If it drains after thawing then get a small length regular electrical wire and twist one end around the heater. You should get enough to extend the other end 2 or 3in into the drain hole. Now when the heater turns on it will heat the wire and thaw any ice in the top of the drain.
If you can't get water to drain then there is something clogging the drain tube and you'll have to find a way to clear it. I use a steamer that has a small tip to build pressure and force the clog out. Hope this helps.
Posted on Nov 02, 2008
imufo2
Leo Ponder
  • 3773 Answers
SOURCE: intergated fridge keeps frosting up
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Posted on Aug 11, 2011
The freezer is leaking a small pool of water intermittently. I have defrosted ice formed in the bottom of the freezer but in another 2 days, another pool of water. I appreciate your advice?
opening the door when it is humid or a bad door gasket will cause that,if the freezer freezes and the fridge gets warm,then it needs a recharge
Jun 14, 2015 | Refrigerators
Frigidaire Fridge Freezer forms huge iceblock inside fridge back wall. It freezes up whatever is stored in fridge i.e. vegtables, cheese. Water leaks onto the floor from under the vegetable containers. ...
the defrost drain pan is plugged up,you need to defrost it and run a wire down the drain tray hole so it can drain to the bottom as it defrosts otherwise it defrosts and runs everywhere else and re freezes
Jun 05, 2011 | Frigidaire GLRT86TES Top Freezer...
Fridge is leaking water from top of fridge and water in bottom of fridge
The defrost drain hole is plugged. you must open that and then the water from defrosting will not pool up below the crispers in the bottom of the frig. Generic ice box Manual and more Here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 27, 2011 | Whirlpool Refrigerators
LG Fridge Icebeam Door Cooling Refrigerator Freezer is leaking water into very bottom of fridge. Fridge is only 6 years old. What could be the cause of this problem ? Many thanks for feedback.
lg ice beam refrigerator which has door cooling also is not cooling properly. the freezer is working there was ice accumulated in the rear corner of the freezer i defrosted but still the fridge is not cooling and there is a pool of water at the bottom most of the time. sometimes i see the fan inside the fridge is not working
Jan 11, 2011 | LG LRTN22310 Top Freezer Refrigerator
Water in the bottom of the refrigerator
Apr 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Pooling of water in fridge compartment of my Neff fridge/freezer
The defrost drain is clogged. Defrost drains usually get there clog right behind the back freezer panel. Remove this to get to the defrost drain and remove all built up ice and clear the drain and you should be fine. Hope this helps.
Feb 04, 2010 | Refrigerators
Bottom of fridge collects water
Hello there:
I have written a few steps for you to follow and try ok?
  1. Manufacturers have different ways to dispose of the water created during automatic defrost cycles. The most common design routes the water down a rubber tube on the back of the fridge to a tray beneath. This tube often gets plugged with breadcrumbs, peas etc. and can generally easily be removed and cleaned.
  2. Make sure the end of the hose is sitting in the defrost tray.
  3. If your hose was not plugged and you have found water running down the back wall inside the fridge or a pool under the bottom crisper has formed. Check if there is a small funnel located on the back wall near the top inside the fridge. It can also get plugged; you can use a small wire and work it in and out of the hole.
  4. Some designs do run the water down the back wall and have a drain hole under the crisper, make sure it is not plugged.
I hope that this has been verry helpfull for you
best regards michael
Nov 06, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Leaking frost-free Zanussi fridge-freezer
Has this thing a separate frezer and cooler compartment.
Have tried to completely defrost and clean that thing.
At times like in airco's the pinch valve for the cooling process to effect (expansion) is stuck frozen, or very seldom broke.
Apr 14, 2009 | Freezers
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Hotpoint RFA60 Bottom Freezer Refrigerator Logo
794 people viewed this question
Top Hotpoint Refrigerators Experts
John Tripp
John Tripp
jasbo
jasbo
jdthefixer
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
