Question about LaCie d2 (300769) 200 GB Hard Drive
LaCie d2 200GB on my Pc (windows xp) via USB 2.0 doesn't show
I have a LaCie d2 200GB on my Pc (windows xp) via USB 2.0
But the HD doesn't show - I can't access - don't even know if ti's there.
Any idea or help? Do I need a isntallation disk or so - don't have one.
Computer did recognize new hardware when I first installed it - but ...
It was previously used with a Mac
Posted by hans820 on
Grand Canyon Tech
  • 3,866 Answers
The situation here is ahppening to all external sata or Esata drives what happens is the external closure has a usb controller when this dies the drive doesn ot spin up or does not reconise simple solution buy a external drive encloser and transfer the drive to it and that will work. thanks and please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Nov 24, 2009
PC doesn't recognise hard drive connected via front panel usb?
Use one of the rear USB ports. Mind you, my PC won't deal with it when connected to any IUSB port although it's fine when connected to the router. This is driving me mad...
Nov 02, 2011 | LaCie Space 2 (301515EK) 1000 GB Network...
I have a lacie had drive that i've been using on my mac. My mac died and I bought a PC instead. How can I retrieve the data I stored on my Lacie?
The easiest way that I know is to purchase a program called MacDrive from Mediafour.com
This will let your PC (Windows XP, Vista or Windows7) read the mac formatted HD directly
They do have a trial version, so you can make sure it'll work for your HD before you pay for it.
Sep 06, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Lacie 1tb ext hd. drive does not show in disk
Your external drive has 2 parts, the hard drive, which is just a normal hard drive you would find in any computer, and the usb bridge, which connects the hard drive interface (either ide or usb) to the usb or firewire or esata or whatever. Sounds like one of these are bad. Does the computer see the bridge? it should show up as a mass storage device in device manager and the safely remove usb devices dialog. If not, then get a new enclosure for the drive. These range from 25-100 dollars. If the bridge does show up, take apart the enclosure and pull the drive out and try hooking it up as a second drive in your computer. If it works there, then you need a new enclosure. If not, then you need a new drive.
Dec 07, 2009 | LaCie Computers & Internet
I have a Lacie 320gb external harddrive which was connected to an eMac and is now connected to an Acer laptop. I've reformatted it as NTFS and it shows up in disk management as healthy but does not appear...
you need to give it a drive letter
A more reliable way to do this is via the computer management console
Start / Control Panel / Administrative Tools / Computer management / Disk Management.
Your drive should show up in here.
if it says Healthy and just above that gives the file system eg. NTFS or FAT32 etc it should be fine but may just need a drive letter.
If it does dot say any of those then right click on it and use the format option. Select how you want to format it (NTFS for XP is preffered)
and then tell it to do a FULL format. and also give it a drive letter !
It may take a while but I find it more reliable overall.
If it didn't have a drive letter then right click and use the Change Drive Letter and Paths option, then add a drive letter and use the one it offers.
I like to re-boot just to be sure windows sees it properly
Aug 28, 2009 | LaCie Hard Disk 320GB with Hi-Speed USB2.0...
My Lacie HD will not show up on my MacBookPro when plugged
Brand new? It needs to be formatted / erased with the disk utility to work with your mac.
Jul 07, 2009 | LaCie (300728U) 250 GB Hard Drive
Mylacie drive is no longer connected to my computer. When it is turned on, there is a clicking noise and the LED light is alternating between red and yellow. What do you think the problem is?
when a disk makes a clicking noise, in most cases (99%) that means that the disk has crashed. i'm sorry to inform you that the data you had on the disk is lost, unless you are prepared to pay lots of money to a company that takes the disk apart to retrieve data manually.
Jun 24, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 250GB Hard Disk is not being recognized by PC (Windows XP)
Some PC's cannot deliver enough power to the USB devices to function properly through the USB port.
Does your Lacie hard disk have a power input connector if so conect a power adapter to it before you put it into your USB port.
Another alternative, get a powered USB hub connect it into your computer then connect the Lacie hard drive to the powered USB hub.
Jan 03, 2009 | LaCie (300728U) 250 GB Hard Drive
Lacie extreme drive 1TB not recognised?
not sure if it will help, but try setting upnp active in your windows services. seem to remembrr my network assistant not being able to see my lacie network drive due to this in the past
Mar 14, 2017 | LaCie Big Disk Extreme (300797U) 1000 GB...
LaCie 2d 500GB isnt recognized
Has the drive been formatted? Before using a hdd it has to be formatted. In Windows XP you have choices of FAT 32 or NTFS format. Hope this helps.
Dec 17, 2008 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
LaCie d2 (300769) 200 GB Hard Drive Logo
449 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
