Question about Nokia N70 Cellular Phone
My n70 is just vibrating and not ringing and is
My n70 is just vibrating and not ringing and is just showing white screen but i can answer call
Posted by machisag on
Anonymous
    President:
  • 632 Answers
The LCD display connector is either loose or the LCD is faulty, the speaker contacts are loose or the speaker is faulty.. Other than that, you have to have it checked by a qualified technician. Follow the procedures below to disassemble the phone and check the LCD, connectors and speaker.
  1. Wear a pair of electro-static discharge (ESD) protective gloves.
  2. Unlock and remove the battery cover.
  3. Unlock the clips of the front cover beginning at the bottom by prying the latches with your fingernail or a prying tool one at a time.
  4. Carefully remove the front cover.
  5. Protect the display with a plastic film.
  6. Remove the 6 screws using a T6 screwdriver.
  7. Swing the user interface (UI) frame assembly upwards from the bottom. Bear in mind that the flex connector is still connected.
  8. Disconnect the flex connector carefully by prying it.
  9. Clean the connectors using a soft-bristle toothbrush with a lacquer thinner.
  10. Remove the engine board and place it in a cushioned non-conducting tray.
  11. Clean the speaker terminals and contact pads on the engine board using a cotton bud with lacquer thinner or alcohol.
  12. Lift up the speaker terminals to ensure it makes contact with the contact pads on the engine board.
  13. Check the resistance of the speaker using a multimeter. The resistance reading should be 20-30 ohms, otherwise replace speaker.
  14. Put back the engine board.
  15. Reconnect the flex connector firmly and reassemble the UI frame assembly.
  16. Remove the protective plastic film and reinstall the front cover.
  17. Insert the battery and turn on the phone.
  18. There should be a display and tone when the hands appear on screen. Otherwise, have your phone checked by a qualified technician.
Check this out for the complete disassembly:
Posted on Nov 24, 2009
WHAT IS THE SOLUTION FOR N70 WHITE DISPLAY How to repair Nokia1100 phone when put the battery ,It doesn't ON, it is vibrating
hi, common problem with n70 white screen, i suggest you take it to a service centre, because it could be 1 of 2 problems, either the lcd is faulty, or, on the main board, there are 2 crystals that control the lcd, they need to be changed, but will be cheaper maybe just to buy a new phone,
as for the 1100, if it doesnt turn on and constantly vibrates, i have a feeling that the phone has liquid damage, and is shorting out.
nick
Aug 27, 2010 | Nokia N70 Cellular Phone
How to repair white screen of n70
it depends if its a screen problem or a virus problem.
Those are one of the things that can make a phone screen to be white.
Put on the phone and use another line to call your phone. If it rings, then it means its a screen problem. But if it does not ring, then its a virus problem.
In the case of screen problem, loose the phone first and check it the screen is well fixed. If well fixed, then it means you have to buy another screen.
But in the case of virus, this means you have to flash the phone.
Best regards.
Feb 19, 2010 | Nokia N70 Cellular Phone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
N70 showing white screen with nokia logo only
proceed to THEMES and then select w/c theme you prefer .
Sep 02, 2009 | Nokia N70 Cellular Phone
White screen
YOUR BOOT IC NEEDS TO BE REPLACED ...SO PLS CONTACT NEARSET NOKIA SERVICE CENTER...
May 17, 2009 | Nokia N70 Cellular Phone
My Nokia N70 fell in water i removed it's battery and dried it quickly but now when i opened it. It is just showing white screen. Nothing else is visible no sound no vibration no display. i cannot turn it...
take a hair dryer and dry the phone till u feel it completly dried off may be then it will work as same problem was with my 6300 phone and its still working
Dec 16, 2008 | Nokia N70 Cellular Phone
Nokia N70 showing white screen.
check the screen connection or get a new 1
Jul 31, 2008 | Nokia N70 Cellular Phone
Phone acting up - screen problem
see if i can help you here on the white screen go to main menu...settings.....personalize......wallpaper you will see picture next ....is it set to none? you can set a wallpaper here. on the vibrate.....main menu...settings....ring styles... is it set on just vibrate? you can change it here to different settings....vibrate....soft...loud...vibrate and ring so if it just says vibrate u can change it there. mine is set on vibrate and ring...down below that you will see vibrate then ring details...here u can choose the ringer u want plus ringer volume and different settings. hope this gets you back what u wanted. jeff
Oct 01, 2006 | Motorola Mobility E815
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Resolution IT Dubai
Resolution IT Dubai
matt
matt
aliasger yq
