Home Logo
Question about Dynamic Home
Drilled a small hole in a pipe while instilling a new basin
Posted by klnepia on
Fred Yearian
  • 5,603 Answers
Depends what type pipe. If a drain or vent in pllastic, you can probably patch by gluing a patch made by cutting a piece of a coupling and using ABS glue.
If it is a pressure line, the only cure is to cut the damaged section and put in a spice. Almost any patch attempted will fail.
Posted on Nov 24, 2009
The outside unit is leaking onto the deck from a 4 cm diameter at the bottom of the unit. How can this be fixed
attach a drain pipe under the hole to drain the water away from the deck area
something like a small basin fitting and then reducers to a 20mm pipe
Where should I drill holes in the cool mist humidifier?
If you need a new hole, seal the original hole and drill your new hole close to it. Make sure your hole is drilled into the reservoir where the mist will still escape. In some humidifiers there is no room to drill any new holes so you will need to be creative with your piping.
I changed the water filter! and now when I use it, it makes a funny sound. Then the flow slows down. what can I door what is the problem.
ck the water valve ( the one at the water pipe where the shut off is . some of thes valve won't let enough water through. due to the small hole in pipe .. best to use a new valve and drill the pipe to 1/4 hole. and use a larger valve. ( they work much better ..mm
Drill chuck is frozen
You may try to put a thick soft metal pipe (aluminium or copper) over the drill bit (longer than the bit itself by ~10 mm) so it will touch the chuck's jaws, then GENTLY hit the other end of the pipe with a hammer several times, holding the pipe a bit askew, thus trying to disengage the jaws from the lock in their thread, and try to loosen the chuck after each series of hits. Just be careful with your fingers, and better hold the drill by the chuck while hammering it - so the hits won't go to the transmission unit (sorry for description - hope it's understandable, if not - ask for clafication from me)
1helpful
Installation instructions for a Glacier Bay Westminster pedistal sink
Things You'll Need:
  • channel lock pliers, mini tubing cutter, tubing cutter for 1 1/2" tubing razor knife, 24"level drill, 3/16"dia. drill bit
  • 3/8" drive ratchet and sockets, tape measure, Teflon tape, 8" adjustable wrench, black sharpie, small edges (cedar wood shakes) 3/8"x 3" anchor bolts, pedestal sink, faucet with pop up drain, P-Trap,
  • sponge, rags,
  • lavatory supplies
The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
  • Step 2 The drain for the sink needs to be set just right so that the finish work will go together easier. When setting the drain make the threads for the trap adapter stick out just past the finished wall. If the threads stick out to far then the escutcheon will not fit up tight to the wall. So check the depth of the trap adapter threads before putting the sink in place.
  • Step 3 Press the small foam pads adhesive side down on top of the pedestal. With the faucet and pop-up drain mounted on the basin place the basin on top of the pedestal. Move both pieces together up against the wall with the drain centered with the sink. Check the pedestal for level. If it is not level use the cedar wood shakes as wedges to make the pedestal level. Don't cut the cedar shakes yet this will be done later. Now adjust the basin to make it level as well. With the sink centered and level mark the points where the anchor bolts will go through the china into the wall. Many pedestal sinks come with a wall mounting bracket if yours does then slide the bracket up under the sink and make it tight up against the wall and the china. Be careful not to move the basin, if you have someone to help you have them hold the sink in position while you're doing this. Now mark the holes in the bracket where the anchor bolts will hold the bracket to the wall.
  • Step 4 Move the pedestal sink out of the way. Use the drill with the 3/16"dia. drill bit to drill pilot holes on the marks that you made. Next screw in the anchor bolts into the pilot holes. Make the wall mounting bracket tight to the wall. The anchor bolts that go through the china need to be removed.
  • Step 5 Take the lavatory supplies and wrap the tops of them with Teflon tape. This will create a gasket like seal. Attach the supplies to the bottom of he faucet. Make sure to get a good tight connection you don't want these to be leaking later on. Next take the J-bend portion of the P-trap and slip it on the tailpiece of the pop-up drain. Measure the height of the center of the drain where it sticks out of the wall. With the basin sitting on top of the pedestal put the p-trap together and make the trap arm the same height as the drain pipe. Mark the top of the J-bend on the tailpiece so you have a reference mark. Next take the basin off of the pedestal and tighten the slip nut on the J-bend. Make this connection secure it will be very difficult to get to this connection later on.
  • Step 6 Move the pedestal into position and set the basin on top of the pedestal. Check the small adhesive pads if they have fallen off stick them back in place. Line up the holes in the china with the holes in the wall and screw in the anchor bolts. Don't tighten these yet you still have to adjust the basin and level the pedestal. Put the cedar wedges back in place to level the pedestal and adjust the basin. Now that everything is level tighten the anchor bolts. Be careful not to over tighten the bolts they could crack the sink.
  • Step 7 Use the tape measure2_bing.gif and measure from the center of the J-bend opening to the trap adapter. Add about 1 1/4" to this measurement so some of the trap arm will be inside the adapter. Cut the trap arm to length with the tubing cutter. Next slip on the slip nuts and washers and don't forget the escutcheon. Install the trap arm. Catch the slip nuts with your fingers and tighten as much as possible by hand. Tighten the rest of the way with the channel lock pliers. You'll notice the first nut on the J-bend is almost impossible to get to that is why you must tighten it before you set the sink.
  • Step 8 Take the lavatory supplies and gently bend them to line up with the supply valve connections. Now mark the supplies where they will fit into the compression joint on the valves. Use the mini tubing cutter and cut on your marks. Slip the compression nuts and ferrules onto the supplies and put the supplies into the valves. Catch the nuts with your fingers and tighten by hand. Now finish tightening with the adjustable wrench2_bing.gif.
  • Step 9 Remove the aerator from the spout of the faucet. Turn on the hot and cold supply valves and run the water in the sink to flush out the lines. When the water runs clear put the aerator back into the spout. Close the pop-up drain and fill the basin with water. While it is filling check underneath the sink for any leaks and repair them if necessary. When the basin is full open the pop-up drain and let the water out. Check under the sink once more for any leaks and repair them.
  • Step 10 Use the razor knife to cut off the excess cedar wood that sticks out past the china on the pedestal. Next caulk around the base of the pedestal where it meets the floor. Also caulk along the top edge of the basin where the basin meets the wall. Dampen the sponge and wipe off the excess caulk to make a smooth caulked joint. Clean up and admire your handy work.
  • 0helpful
    How do I replace the bath sink stopper lift using a Danco universal kit
    Things You'll Need:
    • sponge, rags,
    • lavatory supplies
    • Step 1 The location for the pedestal sink will need to be prepared for installation. Wood backing has to be installed behind the drywall to give the pedestal sink something solid to attach to. Don't skimp on this wood you want enough wood so the sink doesn't move the wood by someone leaning on the sink. Use the dimensions from the installation instructions or set the basin on top of the pedestal and measure for the location of the wood to be installed.
    Mar 30, 2010 • Home
    Broken 11mm stud in a 3 1/8 inch deep hole . head bolt broken in cast iron block, want to remove broken bolt with out removing head.
    First of all, put penetrating oil on it, and let it soak. Tapping distributes the penetrant better.
    If there is still a shoulder of the bolt exposed, you may be able to get it started moving with a small pipe wrench. A hammer helps the pipe wrench. If there is more room, use the largest pipe wrench that you can fit on it.
    There are also grippers available (Sears) that work on rounded nuts, this may work.
    The next option would be to drill the bolt and use an ease-out to remove it.
    After this would be to drill the entire bolt out and install a heli-coil so that an new bolt can be installed.
    Best regards. Hope this helps. --W/D-- please feel free to rate this solution! Thanx!
    2helpful
    Samsung ac model aw25ecb7
    hi! bill,
    water drip it should be outsidethe house,beside there is a spout on the basin of your ac unit and hose to drip off outside the house,all you gonna do insert a piece of wood or metal on front side of basin, in between basin and the wall,just small piece object to elevate the basin to outside wall,the water will not stored in the basin.or make a spout, drill a hole 1/4" size at the corner at the backside of basin out side your house,be carefull not to drill condenser tube or the fan blade,insert a plastic hose 3/16" and weld it by glue gun.and end of hose put it an empty bottle so that the water drip will not scattered outside your house.regards and don't forget to rate me,thank's a lot
    4helpful
    3answers
    Hole in copper water supply pipe
    solution#2 is one way to do it however those clamps will leak after awhile. You can cut pipe on center of hole and (A) push pipe up and install a copper coupling which does involve soldiering. Or (B) you can get a brass coupling fitting called (Shark Bite Fittings) which simply slides over pipe and locks and seals on pipes. This is a fairly new product and godsend to plumbers and plumbing repair. Whenever fixing pipes in walls check for any form of leaks thoroughly before covering up wall.
    Apr 14, 2009 • Plumbing
    Steps on how to replace cv seal on drivers side at trans axle casing
    YOU CAN DRILL A SMALL HOLE NI THE SEAL IN THE METAL SURROUNDING THE RUBBER LIP OF THE SEAL.SCREW A SMALL SCREW IN IT AND USE SOME VISEGRIPS/PLIERS TO PULL/PRY IT OUT. CAREFULL NOT TO DAMAGE THE NEW SEAL DRIVING IT IN. A PIECE OF PCV PLUMBLING PIPE THAT THE SEAL FITS INTO BUT THE LIP OF THE SEAL RESTS ON THE EDGE OF THE PIPE. THEN TAP OR HAMMER ON THE PIPE TO SEAT THE SEAL.
    Top Dynamic Home Experts
    Tom Chichester
    ADMIN Andrew
    ADMIN Andrew
    Are you a Dynamic Home Expert? Answer questions, earn points and help others
