NetGear WGR614 Wireless Router Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Internet is very slow, latency is very high
My internet isp is timewarner cable (earthlink), and i am supposed to be getting 5mb/s speed, however when i did speed test on speakeasy.net and numerious speed testing website, it generally turn out to be 0.5mb/s download speed. i called my isp, and they never give me a clear answer, i have all firewall disabled, and no other program or pc leeching internet. and also checked router settings, no one is stealing my internet. when i play a game, like warcraft3, the battlenet usually gives me a 200+ms ping. and lags the hack out of me.also, i disable all virus scan, update etc.
please let me know if there is anything i can do to solve this problem at my end.
sincerely,
Shubo
Grand Canyon Tech
Level 3:
  • Master 3,867 Answers
  • Posted on Nov 24, 2009
Grand Canyon Tech
Master
Level 3:
Answers
3867
Questions
Helped
1177277
Points
12717
Not the best gaming router out there would not use it for battlenet or war 3 to boot. I would get linksys gaming router by linksys. But to solve you problem you need to run your computer in dmz gamming mode also try any new firmware out there and see if that helps if not part with the netgear and get a linksys gameing router you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Slow internet
A slow internet connection could be caused by any number of reasons.It may be connection or traffic problem.To increase your internet speed use the following tips give below:
1.Clear cookies from your browser.
2.Delete unwanted files.
3.PC Optimization:
It is important to clean your PC regularly.It means a normal maintenance tasks such as, cleaning the disks,registry repairs and Disk Management.
4.If you are using a DSL connection over your Landline, make sure that you have high quality filters in place to get optimum signal speed.
5.Upgrade your modem.
6.Use Updated Browser.
7.Replace your telephone modem with a fast-access connection such as wave ISDN, DSL,Satellite, a cable modem.
8.Consult with your Internet service provider to ensure that your modem is configured correctly.
9.Tweak your router settings.
10.Install Anti virus Software.
11.Reduce your Bandwidth Overhead.
Still your internet speed is slow then,contact your ISP and get a latest speed plan from them.It's a better way to increase internet speed.
After completing this steps, you can check your internet speed whether increase or not using this site ScanMySpeed.com
tip
How do latency and packet loss determine network performance and what can be...
The triumvirate of network performance metrics are packet loss, latency and jitter.
Almost all network applications use TCP (Transmission Control Protocol) to get their data from point A to point B. About 85% of the overall internet's traffic is TCP, of which specific aspect is that it completely hides the packet-based nature of the network from applications. Whether an application hands a single character or a multi-megabyte file to TCP, puts the data in packets and sends it on its way over the network. The internet is a scary place for packets trying to find their way: it's not uncommon for packets to be lost and never make it across, or to arrive in a different order than they were transmitted. TCP retransmits lost packets and puts data back in the original order if needed before it hands over the data to the receiver. This way, applications don't have to worry about those eventualities.
Network latency
TCP has a number of mechanisms to get good performance in the presence of high latencies:
1) Make sure enough packets are kept "in flight". Simply sending one packet and then waiting for the other side to say "got it, send then next one" doesn't cut it; that would limit throughput to five packets per second on a path with a 200 ms RTT. So TCP tries to make sure it sends enough packets to fill up the link, but not so many that it oversaturates the link or path. This works well for big data transfers.
2) For smaller data transfers TCP uses a "slow start" mechanism. Because TCP has to wait for acknowledgments from the receiver, more latency means more time spent in slow start. Web browser performance used to be limited by slow start a lot, but browsers started to reuse TCP sessions that were already out of slow start to download additional images and other elements rather than keep opening new TCP sessions.
3) Also you may use simple open-transfer-close-open-transfer-close sequences that work well on low latency networks but slow down a lot over larger distances or on bandwidth-limited networks, which also introduce additional latency.
4) Try to use a DNS server close by. Every TCP connection is preceded by a DNS lookup. If the latency towards the DNS server is substantial, this slows down the entire process.
Packet loss
Packets are lost in networks for two reasons:
1) Every transmission medium will flip a bit once in a while, and then the whole packet is lost. Wireless typically sends extra error correction bits, but those can only do so much. If such an error occurs, the lost packet needs to be retransmitted. This can hold up a transfer.
But if network latency or packet loss get too high, TCP will run out of buffer space and the transfer has to stop until the retransmitted lost packet has been received. In other words: high latency or high loss isn't great, but still workable, but high latency and high loss together can slow down TCP to a crawl.
2) Another reason packets get lost is too many packets in a short time: TCP is sending so fast that router/switch buffers fill up faster than packets can be transmitted.If TCP has determined that the network can only bear very conservative data transfer speeds, and slow start really does its name justice, it's faster to stop a download and restart it rather than to wait for TCP to recover.
Jitter - is the difference between the latency from packet to packet
Obviously, the speed of light isn't subject to change, and fibers tend to remain the same length. So latency is typically caused by buffering of packets in routers and switches terminating highly utilized links. (Especially on lower bandwidth links, such as broadband or 3G/4G links.) Sometimes a packet is lucky and gets through fast and sometimes the queue is longer than usual. For TCP, this isn't a huge problem, although this means that TCP has to use a conservative value for its RTT estimate and timeouts will take longer. However, for (non-TCP) real-time audio and video traffic, jitter is very problematic, because the audio/video has to be played back at a steady rate. This means the application either has to buffer the "fast" packets and wait for the slow ones, which can add user-perceptible delay, or the slow packets have to be considered lost, causing dropouts.
In conclusion, in networks that use multiple connections to the internet, it can really pay off to avoid paths that are much longer and thus incur a higher latency than alternative paths to the same destination, as well as congested paths with elevated packet loss. The path selecting process can be performed automatically: learnhow to automate evaluation of packet loss and latencyacross multiple providers to choose the best performing route.
on Jan 27, 2015 • Computers & Internet
Streaming inconsistency
This is usually a system or internet latency problem. Check the bandwidth on your internet connection and write down what time of day or night this seems to happen. After awhile look at your log and see if there is a pattern that comes up indicating a time of day that happens more then others. If this is the case it is your ISP throttling your bandwidth because of over loading circuits. It is common for ISP's espeacaliy cable companies to throttle bandwidth to their customers in pike times which slows everyone down.
Jan 11, 2014 • Netflix
2answers
Slow internet download speed
Run a virus and malware scan if not infected your ISP is the problem
My download speed randomly spikes causing my internet to lag and giving me a few mbytes to use
well, First I have to ask what is your ISP and what is your internet speed supposed to be? If it is in fact 1.5 Mbps then you may need to upgrade your internet speed to say 5-10 Mbps.
Also, What applications are you running? Such as Internet Explorer or Firefox? Internet explorer can be nuisance. Things such as Anti Virus Software can hose up your internet speed if you have only 1.5Mbps as well. Hope this helps. If you have other questions don't hesitate.
It would seem that the router is not running fast enough. If I try Netflix it shows my movies but does not down load fast enough to run. What is going on here?
If you are currently using wireless to connect to your router, it might be a good investment to get a signal booster because if you are too far away the signal starts to degrade and slow the internet speed down.
If you are using a wired connection for the connection to the router, there are a multitude of things that could be slowing it down, ranging from internet congestion clear up to faulty firmware.
A few things can be done in order to help speed up the router's/Internet performance.
  1. Close any unneeded programs, this could be all because of a simple program trying to fetch an update.
  2. Check if it is just Internet Congestion, this is a simple one, try accessing the internet at different times of the day to see if there is just too many people running their internet at a time.
  3. Call your ISP, The Internet Service Provider (ISP) could be doing maintence on the network and could be slowing it down. They also could be blocking Netflix from streaming also, so make sure you contact them.
  4. Upgrade your router's firmware, a guide to this can be found on the manufacturer's website. Just keep a backup just in case because anything can happen.
  5. Get a newer cable, if your router is running off a CAT5 cable it could be a simple reason to the congestion. It would be a wise investment to upgrade the cable anyways to a CAT6. A way to identify what cables you have is to check the side of the cable, it probably will be printed on it somewhere.
  6. Turn off/Unplug unneeded Internet Using Devices, if you have a device on the network that uses internet it could be a reason for the latency. Some devices go on the internet to check for news, time updates, software updates, etc...
  7. Time to upgrade Internet Package, this one should be kept for last because it will be the most expensive to do.
These are just a few things that could be happening, but if none of these help, you might want to get a qualified technician to come and inspect the issue.
MY WNR2000 router has High latency and very slow throughput. I have not been able to isloate the problem. I tried to connect directly to my modem that my ISP provided and i was getting excellent throughput...
I also had this problem when I was using the 1.2.0.8 Firmware. I "upgraded" to the 1.2.3.7. Doing so solved the latency issue, but has provided me with a whole new batch of connection problems (dropping connection randomly).
Well my problem it is simple. i have an account with my internet provider, paying for a certain speed: 5mb down - 1.5mb up, instead Im getting 1.5 down and 128KB up, allready it and explain the problem,...
If you're connected wirelessly.. there is a limitation of wireless connection.
Although your ISP sells you a package like 5mb/1.5mb you will probably very rarely see anything close to that speed - depending on the time of day, the distance from the demarcation point, the number of users in your area (yes even ADSL).
Your modem has an ADSL spec seen here: http://en.wikipedia.org/wiki/ITU_G.992.1
< Which negates the 1.5 upstream since it can go only up to 1.3. >
Your modem/isp is limiting you.
As a user - you cannot 'factory reset' your modem (well technically you can but you will end up needing the settings for your isp and it's a very complicated issue) - and flashing your bios won't help either.
2answers
Upload Speeds Slow, Ping High
s it is ur problem of ur LAN card..check the speed of ur LAN card..
2answers
Slow downloading
the porblem seems to be at your ISP.
you need to check with your ISP and verify wha is your upload and downlaod speed. most of the time you should have 5Mb upload and 10Mb download as min.
the speed you are seeing is more like a dialup 133Kb.
Top NetGear Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
