I have the Insignia NS-L26Q-10A26"LCD TV. I've had it for months. Suddenly today the TV would not go on. It just says "no signal".
I tried going to "input" where you set it to TV, VGA etc, to make sure it was set to "TV" and it is.
I tried using the same cable on another TV and the signal is fine.
I then tried using the insignia TV as a monitor to see if there was any problems with the picture. And it works fine as a monitor.
SO as it stands it's not a problem with the cable,
it is set on "TV"
and also the picture is fine when it is used as my monitor.
Also nothing happened to the TV since last night when I was watching it, and this afternoon when I turned it on.
It's on the wall so it wasn't inadvertently hit into or anything.
This just doesn't make sense. Does anyone have any ideas of what might be happening or what I could do ?!
I just bought this thing a few months ago! It's not like it's had a long life. It's actually probably not covered by warranty anymore since most of them are only up to 3motnhs or so... Don't tell me this is one of those pieces of **** that's made to brake down after the warranty is no longer any good.:(
SOURCE: Insignia LCD HD tv with "No Signal/VGA input"
Your Television need to be reset. Take the back off carefully, locate your picture lamp, somewhere in that area should be your reset button. Your television needs to be powered on, so be very carefull not to touch anything other than the reset button, hold the button in until your TV goes blank, then release and put your cover back on. That's it, your TV should be back to normal. You might have to run your setup again.
SOURCE: insignia is-lcdtv26 26", NO SIGNAL
This TV (Insignia) has been recalled (Model # : IS-LCDTV26) - Best Buy AS OF 04/02/2009 is STILL holding recalls for this TV due to fire hazards & power supply failure - the official report is here ->
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09183.html
Contact best buy's customer care hotline @ 800-233-0462 to get a gift card for upto $800 if you own this TV (Insignia - Model No. IS-LCDTV26)
SOURCE: VGA connection just reads "no signal" Brand new TV and VGA cable.
i have a 26" insignia lcd tv that i use as a montor uou musr set the screen resolution on your computer to 1024x768. if you use a higher resolution it will say no signal.so use your montor to set the resolution to 1024x768 then hook it to the vga and it should work. bob griggs
SOURCE: Insignia NS-LCD32 - 32" 720p Flat-Panel LCD Turns itself off, resets, then turns back on
It's haunted. You must appease the spirits with a virgin sacrifice.
SOURCE: My insignia NS-L26Q-10A 26
This may have to do with the settings on your DVD player or cable/satellite box. Change the settings on those devices to output the desired resolution (720p) and adjust your TV settings appropriately. More details about the TV settings can be found in the owner's manual.
