Televison & Video Logo
Posted on Nov 24, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I escape from an input screen back to watching satellite tv? Screen reads first please connect all signals and antennas to jacks and terminals on the back of the tv then press the channel up key Which is fine but I am not using an antenna I am using a sat receiver
Jacques Marin
Level 3:
  • Master 566 Answers
  • Posted on Nov 24, 2009
Jacques Marin
Master
Level 3:
Answers
566
Questions
Helped
156508
Points
1683
Looks like your set is not receiving the signal from the sat. receiver. Make sure that the audio/video cable is in good shape and connected correctly, then select the correct input on your tv. If that doesn`t work try to connect a dvd or vcr on the same cable, if that is still no go then you may have a bad audio/video cable or there is a problem with your tv set. If it does work(dvd/vcr) then you`ll have to check your satellite receiver. Hope this help. Good luck
Where is the antenne hookup
How to Hook Up a TV Antenna: 7 Steps (with Pictures)
www.wikihow.com > ... > TV and Home Audio > Television
wikiHowHow to Hook Up a TV Antenna. Two Parts:Picking an AntennaConnecting the AntennaQuestions and Answers. Want to ditch your cable, but still like to watch the ...
How to Connect an Over the Air TV Antenna to a Flat Screen ...
? 6:37
https://www.youtube.com/watch?v=9Pq8e57O4zk
Sep 19, 2012 - Uploaded by All About Home Electronics.com
How to watch digital channels without cable TV or satellite for FREE? ... How To BUILD The BEST HDTV ...
How to Connect an Antenna or Cable to Your HDTV - Video ...
www.dummies.com/.../how-to-connect-an-antenna-or-cable-to-your-hdt...
The first step to connect an antenna, is to find the input port on your HDTV. Look for the VHF/UHF input. It's usually on the side or in the back of your HDTV.
3answers
How do I hook up a HD satallite dvr to a av reciever dvd player and HDTV using HDMI cables
Things You’ll Need:
  • HD television
  • HD satellite or cable receiver
  • DVD player
  • Stereo receiver
  • AV cables
  • Cable connector
  • HDMI cables
Step1Examine the back of your HDTV. You will see a series of input jacks for AV cables, (typically color-coded white and red for audio and yellow for video), as well as an antenna input and one or more HDMI input jacks. There will likely be a number of them, but each one should be distinguished with a label ("video," "cable" or something similar). Step2Attach the cable connector from the cable or satellite receiver to the antenna input on the back of the TV. Step3Connect the AV cables to the DVD player, VCR, stereo receiver or whichever other component you wish to connect to the television. The cables should line up by color: place the white cable in the white input jack, the red cable in the red input jack and the yellow cable in the yellow input jack. All three cables from each component need to go into the same label input jacks. Usually, they will all line up in a vertical row. Step4Find the HDMI output jack on your receiver or DVD player (some receivers will not have them--they are necessary to receive a high definition signal--but can still play on the TV through the cable connector or AV cables). Attach one end of an HDMI cable to the output jack of the receiver and the other end into the input jack on the HDTV. Step5Turn on the TV. Access the menu with your remote, and follow any instructions it gives you. Your HDTV may require a few additional steps to complete the hookup of the receiver (though not all of them will). Step6Access the "input" button on your TV remote. This will allow you to switch the TV signal to one of the cable connections you have just made. For example, if you attached the HDMI cable to the first of two HDMI input jacks, the TV will flash "HDMI 1" on the screen to tell you that is where it is receiving its signal. Hope that helps..........
Have no picture just keeps say no signal
Check the input jacks in the rear. Each should have a unique label. Pick one input that has cables connected to it. Note the input name. Follow the cables back to the device connected - DVD, BluRay, Cable / Satellite box, etc. Turn on the TV, and select the same input you noted above. Turn on the device connected to it (DVD, BluRay, Cable / Satellite box, etc.). If this fails, try again with a different device or connect the cable / satellite box to the antenna input and select ANT.
All other input works fine e.g. dvd, TV went pink screen.
If other inputs show no problems and you are not using a cable box or satellite receiver, etc. just off air antenna, something on the main board is failing. please double check other inputs again.
1helpful
PICTURE SEEMS TO BE BLURRED WHEN ITEMS MOVE FAST ON SCREEN, ESPECIALLY PERSONS IN CLOSE UP.
The Sony Bravia KDL-32BX320 generally gets excellent reviews (4.5 stars out of 5) from owners, so I have to wonder what you're watching.
This is an HDTV and should excel when provided an HD signal to display. SD (standard definition) signals often look worse on an HD display than on an SD display. An HD signal is only available via the following ways (reference the image below):9_27_2011_4_28_11_pm.jpg
1) An "over the air" (UHF / VHF) antenna is connected to the cable / antenna input and there is a broadcaster of HD content nearby (only an over the air antenna can input HD signals to this jack - no cable boxes, etc.).
2) An HD Cable TV, DirecTV or Dish Satellite set top converter, Blu Ray Disk Player (or other HD source is connected via HDMI or Component RGB jacks.
3) An HD video played back from a computer hard drive connected to the VGA jack (when the computer is equipped with a modern processor and video card).
You will NOT be able to view HD video if:
1) The source material is a SD (non-HD) source. An over the air antenna will not provide HD signals if the broadcaster does not have HD content to show or is not capable of broadcasting in HD. Digital is not necessarily HD.
2) The source material (other than over the air antenna) is connected via Antenna / Cable jack.
3) The source material is connected via Composite jacks.
The USB jack is generally not an input for motion pictures, but may display stills - depending on the TV's ability to play the format they are stored in (jpeg, gif, bmp etc.).
Hopefully, this will help you solve the problem you're having with the picture. Good luck!
I need the wireing to hookup to a tv.
Hi, it depends on the kind of TV your using...
How to Hook Up a Receiver to an HDTV
Though it utilizes the most sophisticated technology on the plant, an HDTV is extremely easy to hook up to a receiver. Home entertainment systems are designed for compatibility, whether it is a cable or satellite receiver, a DVD player or a stereo sound system.
Instructions
things you'll need:
* HD television
* HD satellite or cable receiver
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Tips & Warnings
Not everything that can be hooked up to an HDTV is capable of playing in high definition. The signal needs to be HD as well, which means that only HD broadcasts, HD DVDs and Blu-Ray DVDs can play in full high definition (though "upgrade" DVD players will allow normal DVDs to play at an enhanced picture). You can still hook receivers up to an HDTV, and it will still play broadcasts from them as clearly as the signal permits.
1helpful
I cannot get any sound to the speakers, hooked up receiver to new HD tv and not what input source or settings to use??
Hi, it's a general process to connect any receiver to a HD TV.
Things You'll Need:
* HD television
* DVD player
* Stereo receiver
* AV cables
* Cable connector
* HDMI cables
Instructions
Tips & Warnings
Hope it helps.
Good luck..
1helpful
Screen has gone to blue screen.....
OK A Blue screen, indicate that there is, or the TV "Thinks" there is NO SIGNAL. Please Check your Antenna Connection. Unplug the TV, for 5 mins or so. You MUST prove either the TV or it's "Signal Source" the Antenna. Try the antenna on another TV, if possible, try another antenna,on the TV, Try feeding in a signal via the EXTERNAL inputs. IF ALL Inputs are proved OK, and the TV, still will NOT display any signal, then it would appear that you may have a "Tuner" fault, or some other underlying condition, that affects the reception. In my professional opinion, in that case is to get the unit looked at by a Toshiba, recommended service center, VERY IMPORTANT to do that. Ask for a "Quote" from that service center, and go from there.
1helpful
Purchased model NS-LCD32 second hand with no
Since you are getting the signal from the satellite, leave the satellite receiver ON and press input on the TV buttons until you get the signal back, wait 2 seconds after pressing the input button. Make sure the TV is on channel 3 if you are using the antenna input.
Let me know if you need further assistance.
How to connect tv set to digial tv tuner converter box
There are two ways to connect a converter box.
The simplest is to use the RF antenna cable supplied with the converter. Connect it from the box (the round threaded connector) to the TV's antenna/cable input connector and put the TV on channel 3 or 4 (whichever the converter box is set to). If your set has screw terminals for the antenna connection, you'll need an adapter to switch from the round cable connection to the screws. This may also have been supplied, but you'll probably need to pick one up at Radio Shack or another retailer.
The other way, if your TV has the inputs, is to use the audio/video output jacks on the converter. Again, the cable is usually supplied with the box. This direct connection gives better picture and sound quality than the RF method. The jacks are color coded: red and white for the audio right and left channels, yellow for video. Just connect them to the matching jacks on the TV and select the video input to watch the box. (If your TV is mono and has only a single white audio input jack, you'll need a Y-adapter to join the two audio signals from the box into one. This is also available at Radio Shack. If you don't do this, you'll only get one channel of the sound when watching a stereo channel.)
Please take a moment to rate this solution if you found it satisfactory. Thanks for asking!
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
