Question about Canon PIXMA MP530 All-In-One InkJet Printer
Mp530 u052 check cartridge u052 alarm showing. Printer will not respond. All cartridge lights are solid red (the way they should be). How do I fix this?
Posted by levi63366 on
Ted K
    New Friend:
Had the very same problem on my faithful mp530. After I replaced the print head with a new one, everything worked fine again.
Posted on Jul 24, 2015
Anonymous
    President:
  • 787 Answers
Try press and hold reset button for 5+ seconds.
Posted on Nov 24, 2009
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
CHECK CARTRIDGE u052
Remove all ink tanks (printer is on), remove printer ink cartridge carrier head. clean head with alcohol wipes thoroughly, not contacts. Push in gently print cartridge pistons on cartridge carrier. Reseat print cartridge and ink tanks, replace any very low ink one's. turn off printer, unplug electrical, remove usb on printer and computer. plug all back in, turn on. Alarm and message should disappear. Clean and realign with software.
Feb 07, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Check ink U150 Alarm is on then i click all the ink cartridges down soall the red lights are on but when i close the lid the Alarm goes off again i have replaced all the ink cartridges with new ones...
After you have rechecked that they are all fitted correctly, (which I know you have already done,) check to make sure that the lid is engaging the switch that will show that it is closed correctly. If this fails, remove each cartridge and see if its switch is OK and not damaged. Once this has been achieved and it still does not respond, it is time for the proffesional.
Before you do that though, try a reset of the printer:
1. Turn the printer off with the Power button (if available).
2. Disconnect the data cable from the printer.
3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in.
4. Turn the printer back on.
Feb 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Hi their My MP530 printer reads CHECK CARTRIDGE U052, the manual does not help, can anyone help me please?
The dreaded U052 error means that the 'chip' fitted to the Cartridge is not responding .. Canon (like all printer mfgs) makes all it's profit from selling Ink .. so they fit these chips to try to prevent you refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and (it seems) the chips are particularly sensitive to static / damage .. many people end up blowing the chips during the swap over .. or even when fitting the original genuine cartridges to a brand new unit for the first time ...
If the unit is brand new, take it back and demand a replacement ... if you have just swapped over the chip onto a compatible cartridge, you can try buying a genuine Canon cartridge (which will have a new chip) = hopefully that will do the trick
Nov 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon MP530 U052 Error
Reseat the Print Cartridge. Go to Canon site (see below) and search for U052 error. I followed the directions with pictures and the error went away. http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
Apr 09, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Printing Error...
Hi!
The U052 error means that the 'chip' fitted to the Cartridge is not responding . They fit these chips to try to prevent refilling or using a 'compatible' replacement cartridge
You have to move the chip from the Canon cartridge to the 'compatible' and the chips are particularly sensitive to static / damage. Many people end up blowing the chips during the swap over
Please rate this solution.
Thanks
Rylee
Feb 10, 2009 | Canon PIXMA MP530 All-In-One InkJet...
NB. I have seen some suggestions that canon's have a 'Service Mode' that allows you to disable the cartridge chip checking and allow you to print no matter what .. however I've never found any details ... perhaps some-one else has the details ??
Feb 05, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
2,665 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
