What kind of label can use for
DATAMAX I-4208 Thermal Label Printer?
Well, it depends whether you'll use the printer as a Direct Thermal printer or as a thermal transfer printer. If it'll be a direct thermal printer, then you can use any direct thermal labels (up to 4" wide, which is the with of the printhead on the Datamax I-4208) without the need for any ribbons. If it'll be a thermal transfer printer, you can use thermal transfer labels, which would need ribbons. As for the kinds, you have a huge variety, you can use paper-based labels, synthetic labels (PPE, Vinyl, Tyvek, belt tags, jewelry tags), and even some kinds of card stock and satin.
Not sure what you're looking for? Visit www.bartechsystems.com for a range of barcode and label supply solutions
Posted on Jun 24, 2022
Any Thermal Transfer or Direct Thermal label on a 3" i.d. roll with maximum o.d. of 8" and label width between 1" - 4". Thermal transfer labels require appropriate ribbon.
Posted on Apr 29, 2014
SOURCE: Datamax problem
You probably need to adjust the leveling cam if you have not done so already. This is the green thumbscrew near the print mechanism.
Posted on Feb 12, 2008
SOURCE: Datamax M-4208 label printer is not printing. It
probably a bad or very dirty sensor - use compressed air to blow out the sensors (look in the user manual to locate the sensors)
Posted on Dec 09, 2009
SOURCE: Datamax I-Class Thermal Label Printer:
Check job darkness setting and you can downlaod manuals on www.datamaxcorp.com
Posted on Apr 15, 2010
SOURCE: datamax m 4208 thermal label printer.
Check out this link. It doesn't seem to have the solution, but you could call their tech support. the number is in the link.
http://www.datamaxcorp.com/support/tech/mclass/
Posted on Apr 28, 2010
SOURCE: why wont my datamax 4208 printer read the same
It will read and print the label format, but you need to download and choose a different driver for the other printer. Seagull Scientific makes the drivers for Datamax, so visit their site for the most recent versions. you will need to open your label format in your software, duplicate the label format and choose the new driver for the I-4212.
Posted on Nov 18, 2010
