Linksys Wireless-G WPS54G Print Server Logo
Question about Linksys Wireless-G WPS54G Print Server
How can I connect wireless G print server to a 65bits windows vista without a problem, it just works for WIN XP
Posted by fjavierlara on
Anonymous
    New Friend:
Hi, it appears that many are having problems with the WPS54G Print Server. I too have always found it hard to get pc to connect to it. My latest problem was with a Win 7, 64bit pc.
Setting up a printer with a print server is a two part configuration. First you need to configure the print server and then add a printer in your OS.
The following instructions are for a linksys wireless router and the linksys wirless print server model # WPS54G.
To set up the print server correctly go to this link.....http://www6.nohold.net/Cisco2/ukp.aspx?pid=80&login=1&app=search&vw=1&articleid=4142&donelr=1
Following is the instructions from the above link:
Title: Connecting the PrintServer Wirelessly to a Wireless Router Article ID: 4142 Before configuring the wireless settings of the PrintServer, make sure to know the following settings on your linksys router: SSID, and wireless security. To check the wireless settings on the linksys router, click here.
Configuring the Wireless Settings on the PrintServer
The wireless settings of the PrintServer can be configured using its web-based utility. Make sure the PrintServer is set to a static IP on the network.
Record the Print Servers IP address you will need it later.
NOTE: Make sure the PrintServer is already working when hardwired to the linksys router before attempting to use it wirelessly on your network.
Step 1:
Access the PrintServer’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the PrintServer's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the PrintServer setup page appears, click Wireless.
Step 4:
Enter the same SSID you have on the linksys router. Make sure the Network Type is set to Infrastructure then click Save to apply your changes.
Step 5:
Click Security and look under the Security Mode field. Select the type of wireless security your router is currently using then enter the corresponding security keys.
Step 6:
Click Save to apply the settings then close the PrintServer setup page.
Step 7:
Unplug the Ethernet cable connecting the PrintServer to the linksys router. Power it off for 30 seconds then power it on.
Step 8:
Make sure the Wireless LED on the PrintServer is lit and the Ethernet LED is off to indicate that the PrintServer is in wireless mode then try to print wirelessly.
Stop if you can print at this point. If not continue. The following instructions are for Windows 7, 64 bit OS.
Once the above steps are completed open windows file explore. Click Network and you should see a "print server" listed. Click on PRINT SERVER and you will see a network icon labeled p1.
You should now be able to add a printer.
In win 7 open the add printer and click "Add a network, wireless or Bluetooth printer", and click next. A searching for printer window pops up. It will list any network printers or print servers it see's on your network. You should see a listing titled "p1 on Print Server".
At this point you need to click "The printer that I want isn't listed. This is just below the "Select a printer" box.
Next a "Find a printer by nane or TCP/IP address" window opens. Select "Add a printer using a TCP/IP address or hostname. Click next.
Another window pops up which ask for a printer host name or IP address. Enter the IP address of your print server (the one you recorded when setting up your print server), and click next.
The next windows states the device is of unknown type. Under Device Type, make sure Standard is checked. Out to the right is a down arrow, click it and you should see many different devices displayed. Scroll until you find "Hewlet Packard Jet Direct", click on it to select it and click next.
Finally a "Install the printer Driver" window should open. Select your printer and follwing the instructions. If your printer is not listed you can click "Window Update" which will look for new printer divers. Once the printer driver is installed you should be able to print.
As you can see this in not a simple printer install. Good luck!
Posted on Sep 04, 2010
Prashant M
  • Linksys Master
  • 2,278 Answers
The print server works with WIN XP. that means it is working and you don't to set up the print server again.
For Windows VISTA, you will need to add the printer port manually.
Do you know the IP address of the print server ?
You just need to add TCP /IP port for that IP address
Click Here for more info
Posted on Nov 24, 2009
3 Related Answers
Anonymous
  • 52 Answers
SOURCE: Upgrade failure
The software that came with the WPS54G model is not (yet)compatible with Vista systems. This model is not listed on the Vista-ready devices from Linksys' website (www.linksys.com/vista). The behavior more likely a result of a software incompatibility.
For PrintServer network setup, you may still use the CD on a non-Vista system (XP, Win2000 or lower). Or, by installing it manually by accessing it's web interface.
To make your Vista working with the printserver WITHOUT the use of the PrintServer CD, do the ff:
1. Make sure PrintServer is configured on the network with the same wireless settings of your router and with a manually assigned IP address which is in range of the router's IP segment.
2. Make sure that computer can print locally to the printer (e.g. via USB connection to the printer).
3. When computer can surf the net and connected to the router's network (wired or wireless), follow the steps from this article and make sure Printer is showing up as Online.
Posted on Jul 09, 2008
Anonymous
  • 52 Answers
SOURCE: Problem with Linksys Wireless-G WPS54G Print, PS can't be found.
Check the settings on your wireless print server. And as well check your router.
Posted on Jul 26, 2009
Anonymous
  • 449 Answers
SOURCE: HOw do i set up the print server without
the printer has no wireless device installed, so that is not possible. since the printer needs a wired network to work then go on wired.
Posted on Aug 01, 2009
Polaroid PMP 120-4 driver
THere are drivers for Windows Server 2008, Windows Home Server, Win 64-bit, Windows Server 2003, Windows Vista, Win Server 2003, Win Me, Windows XP, Win Server 2008 R2, Windows 98, Windows 98 SE
I'm not sure if theres is a drivers for Win 7 or Win 8 so if you don't have one you should install Windows Vista or XP driver using compatibility mode
2answers
I have a wpsm54g successfully connected to my router and 2 XP laptops that can print via the print server. A friend has a win 7 laptop that we want to connect to the print server but the linksys install...
go into the control panel and add a wireless printer, it should detect it on the network.
if this doesnt work try going on the website and locate the driver
Print jobs don't get into a queue when print server is offline
you must repair sharing to your all network,if not work you must check cable Lan connection try this.good luck
Printer is connected via USB to a Win XP PC and prints fine. However will only print test print from networked Vista laptop?
I take it you the Win XP PC is on the same network that your Vista Laptop is on and that some how you must be able to share the printer through your XP PC?
I think you are experiencing the many issue that Vista has to offer.
Maybe think of actually seeing about placing the printer on a Network print server. This would solve your issue. I did this with my Brother Laser printer and it works great. I believe the print servers are coming down in price I am using a TRENDnet TP100 and it works great with my two wired network desktop PCs and the two wireless notbooks that both have Vista on them.
Blessings,
A/V Media Guy
2answers
Need win xp driver for advent t2250
You need to partition the hard disk on vista and then install xp on the other partition.Once xp is loaded it won't be hard to find drivers as long as you have internet connection.If wireless fails then use an ethernet cable to start with for the sake of web connectivity.
4helpful
3answers
Have a ps 110 netgear printer server Vista will not requnize it
I have no problem using Vista Home Preimum notebook that print to the NetGear PS110, and now the notebook upgrade to Windows 7 Preimum, it still works. All other computers using XP, Win 2000, all work fine with PS110. Basically, install the printer drivers to LPT1 first, then add a new local port with \\PSNNNNNN\P1, then it just work. no problem. (note that, you have to configure the PS110 using same subset ip address first.)
1helpful
Upgrade failure
2answers
Printer Sharing
Hi jammin dave,
There are certainly known issues with sharing a printer installed on an XP machine to a Vista machine. First question is whether you have Windows Live OneCare installed. This in itself causes known sharing problems.
2answers
Linksys WPS54G
Hi Scott.
Make sure your firewall is set on the Vista to allow the network discovery. Follow this link, click on Networking>File and printer sharing. It will tell you how to setup Vista to work with printer
http://windowshelp.microsoft.com/Windows/en-US/networking.mspxsharing.
This link should help, too. It is just for your Printe server.
http://www.experts-exchange.com/OS/Microsoft_Operating_Systems/Windows/Windows_Vista/Q_22960040.html
Good Luck!
Top Linksys Computers & Internet Experts
Donivan Wise
Mike
Mehandi Husain ...
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
