Might be the power supply board. Check for a solution here: http://www.coppelltvrepair.com/p/795/lg-42lb4d-power-supply-board-repair-serivce-for-totally-dead-not-powering-on-or-shutting-down-tv
Shutting down still have power?No,change the power board,not change the backlight video board.
ngine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
