Question about APC BR1500LCD UPS System
APC BR1500LCD Fault F01
What does the fault mean ? instuction sheet not clear.
  • 32,281 Answers
This is a printout of the fault codes
System Fault indicator is on and all other
front panel indicators are flashing.
Internal UPS fault. One of nine Internal UPS Fault Messages is displayed:
F01 - On-Battery Overload F06 - Relay Welding
F02 - On-Battery Output Short F07 - Temperature
F03 - On-Battery XCap Overload F08 - Fan Fault
F04 - Clamp Short F09 - Internal Fault
F05 - Charger Fault
Posted on Nov 23, 2009
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
How does one remove the case from an APC BR1500LCD BackUPS?
To change the battery?
Pull hard from the TOP of the front panel. When the plastic part comes off, There will be a metal cover. Remove the two screws and remove the plate again from the top.
Dec 21, 2013 | Mustek PowerMust 800 (POWERMUST800USB) UPS...
APC SURT3000XL UPS
The fault indicator means that there is a fault in the circuitry of the UPS. It could be the control board or another part of the system. (If the batteries were bad, you would see the Replace Battery light illuminate.) If the SURT3000XL is under warranty, contact APC. The standard warranty period is 2 years for repair/replacement. Note: you'll probably have to pay for the shipping of the unit. If the unit is out of warranty, replace it with a new UPS.
I hope this helps.
Nov 13, 2013 | APC Computers & Internet
Error f01 flashing on machine
F01 on a Washer Dryer means you have a motor fault.
I suggest check the motor and associated wiring. You may just have a broken wire.
Hope this helps.
Oct 08, 2011 | Hotpoint Aquarius WD640 Front Load...
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
Aug 18, 2011 | Washing Machines
Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
Jan 09, 2010 | Washing Machines
I have a Hotpoint ultima wt960 with f01 error can I fit the part
Hi
f01 means motor fault. remove motor and check the brushes. if ok then fault could either be motor or pcb which is faulty.
regards
Mar 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
WHAT IS FAULT F01 ON MY WASHING MACHINE WF860
F01 indicates a short circuit motor triac, this is part of the motor speed control, either in the motor, or the control unit, and as such is something you cannot repair yourself.
It means that you will have to call hotpoint unfortunately.
If it is under 5 years old, then you should be able to get it done under the 5 year guarantee.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Washing Machines
APC BR1500LCD  UPS System Logo
8,837 people viewed this question
Top APC Computers & Internet Experts
Gruber Power...
Gruber Power...
Vincent G
Vincent G
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
