Some XBox games have both a 360 and original XBox version, so you can't play them on the 360. Other games simply aren't compatible. Your game may fall into one of those two groups.
Only certain original xbox games are backwards compatible on the Xbox360. To see a list of which games those are you can go to www.xbox.com and search for games that are backward compatible for the 360. You may have to download something onto your xbox360 to play the old games.
The XBOX360 requires a update file for each XBOX game to play on it. Not all games are supported. If your XBOX360 is connected to the internet it will automatically check for an update when a XBOX game is inserted. If your XBOX360 is not connected to the internet then you can burn a DVD or CD rom from a computer with the update files and insert the disc into the XBOX360 and update the files. Or you can load then to a USB jump drive and plug the jump drive to the USB port on the XBOX360 and update from that. The details are available from here http://www.xbox.com/en-US/support/systemuse/xbox360/console/systemupdates.htm
And remember not all XBOX games will play on the XBOX360. Only ones with updated files. So if it does not play after the file update then it is not supported. Microsoft updates these files quarterly so check back once a month for more updates.
you do it is very simple , you can manually fix your problem with the use of repair guide,,
it is a complete version to fix your problems caused by xbox.
if you want to download click here.
If your console is hooked up to Xboxlive and has a Hard Drive connected to it you will automatically be prompted to update upon insertion of the original Xbox title. Your console will restart when it's ready and you should be able to play.
*If you do not have a Hard drive you cannot play original Xbox titles.* The original Xbox Memory unit will not work in Xbox360 and the original Xbox games have no access to the Xbox360 memory units.
If you have a Hard Drive but your Xbox360 is not hooked up to the internet you can either order a disc for free from Microsoft by going Here
or burn the needed information onto a disc by going Here
