Question about Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
Posted by jbossenberry on
Half Carrot
    New Friend:
Roberta Smith
    Brigadier General:
  • 5,158 Answers
Krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Posted on Nov 23, 2009
3 Related Answers
Anonymous
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
Anonymous
SOURCE: Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Posted on Feb 04, 2009
Anonymous
SOURCE: My Rowenta Garment Steamer will not steam up.
I had the same problem and noticed that there is a small plastic piece that pushes into the water reservoir to release water into the boiler. Mine broke off, and no water leaves the reservoir into the boiler. It looks like suspect design to me, and I havent found a replacement part but I may try to epoxy the piece back on to solve the issue (I hope)
Posted on Apr 23, 2009
My Rowenta steamer is brand new never used before. I added the water it worked for 5 minutes then stopped and now it won't steam at all
Hello, Nadya -
Check the warranty information which came with your Rowenta steamer (probably in the owner's manual / instructions. Find out what you need to do to return the steamer for a working replacement.
Best wishes.
Mar 07, 2018 | Rowenta Irons
My Rowenta steamer tank leaks steam with a loud whistling sound after about 10 minutes of being turned on. please help.
The tank must have corroded through, have a local appliance repair look into a possible fix.
Oct 21, 2016 | Rowenta Irons
How to clean a Rowenta steamer
WHen cold tilt over sink and empty and rince every 3-5 uses depending on how much you use it. Water sitting in the tank gets moldy and bad, rinse tank and use Britta type filtered water only.
Jun 18, 2014 | Rowenta Commercial Garment Steamer - White
A PIECE BROKE OFF OFF THE MAIN BODY WERE THE
Try filling the hole with some fibreglass resin ( the stuff that motor car shops sel for fixing car bodies). This would provide a quick setting, hard filler.
Dec 14, 2009 | Rowenta Commercial Garment Steamer - White
I need to purchase the thermostat/steam generator that is inside the water tank of the rowenta dg050 iron/steamer. where can i find that part? i know it is the problem
I would call a Rowenta service center to find the part and cost. If you are in the US go to the After Sales Service, Service Centers at
http://www.rowentausa.com/rowenta/frame.aspx
If you are outside of the US go to the www.rowenta.com site and select your country.
Aug 09, 2009 | Rowenta Steam Generator DG050 Iron
IS8100 Commercial Steamer is leaking water
Try "cleaning it" with vinegar. It could be clogged with calcium carbonate. Replace the water with a potent solution of white vinegar and water and operate the unit until the vinegar solution is used up. I use 100% of the supermarket white vinegar and avoid breathing in the "steam." Repeat the procedure once or twice with plain water. If this works, let me know.
Dec 24, 2008 | Rowenta Commercial Garment Steamer - White
Rowenta Steamer
Same thing with my daughter's..any solution out there?
Jun 22, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
Rowenta Commercial Garment Steamer - White Logo
971 people viewed this question
Top Rowenta Irons Experts
Paul Bade
Fahr Quad
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
