SOURCE: LCD TV won't turn on, Screen and Standby light blink
I had a similar problem which I have partially solved. The power light flashing could be due to a shorted electrolytic on the power supply board but in my case it was a shorted IC on the main board, the one with the input connectors. The IC marked 7001 shorted and got hot enough to melt the plastic. Replaced it with a new one from Mouser. The supply measured on the end of inductor 5001 farthest from the IC reads 12V now. This is a surface mount part and has a pad on the bottom that may be soldered to a pad under it. I had to cut the IC apart carefully with a Dremel cutoff wheel to remove it. That fixed the problem with the light and the remote now turns the TV on and off so the logic is working.
I now have the problem of the backlight not turning on. The driver board, the ones with the transformers, are made by Intechwave, the only info I can find is here: http://www.peopleworks.co.kr/kor/product/product_list.php?intDivision=4&intClass1=16&intClass2=41
This a 45kHz RF driver and it is not starting. If I can figure out why I'll post it for all the people who reported slow or no turn on of the backlight. These boards should have 24V between the red wires on the connectors and ground, as mine do.
SOURCE: standby light flashing on and off samsung le32r74bd
samsung tv le32r74bd standby button keeps flashing no piture
SOURCE: my power light on hitachi lcd is flashing red and
Sadly to the end I can now explain the "problem" of my question by myself ...
Because I'm was not sure if I can handle the "problem" by myself I gave the Screen to a technican at our City with all the Information I found until this point (By the way my suspicion was the defect of something at the power supply unit). Two days later he gave me a call with the information about the error: An error at the power supply unit - spare parts => 50€, Work => 200€).
Unhappily im not yet got at soldering on screens, but for 250€ i would have made a good course for this (and if I can establish i will learn it).
So now again a bit more objectively:
Error / Problem:
TV - Step 1: Power Off
TV - Step 2: Stand-By
TV - Step 3: Power-On
TV - Step 4: Short flashing picture
TV - Step 5: Reverse to Step 1
Solution:
1. Find the defect Fuse/Safe/...
2. Buy the Spare part at eshop2.euras.com
3. Change the parts -> et voilá
Hopefully I could have been a little help for someone.
With kind regards,
NatureOneFreak
SOURCE: WONT TURN ON
Most likely, the problem is a defective Main Processor Board. This is the board with the antenna, RCA and HDMI plugs. You cant repair or replace component parts on this board, so dont even try. You must replace the complete board. The TV says Sylvania, but it is a bloody Funia TV. Several years ago this foreign company bought out broke-azzz Sylvania . They are still carrying the Sylvania name since Sylvania was a popular TV name in the 70s. Every electronic company in the USA is now owned by the Chinese, so call Funai and order the part from them. Dont be surprise if they dont have a clue what the heck you asking for. America and all electronics have gone to the puddles. Do you know why? GREED.
SOURCE: Sony Bravia LCD TV stand by red light flashes 13times
Really? Nobody has a better solution? I have the same problem and the tv's about a year old. That's it!
Crazy!
I have same thing with my tv
