Console not reading the disc
Few of the various methods ...
Try updating the firmware... Also, check if any other disc works or not.. If it does, then get the disc which you have inserted is at fault, try to replace it... If that's not possible, try cleaning it by various methods... If all else fails, and you have no other option but to throw that disc, try using toothpaste on it ... It works sometimes..
SOURCE: gamecube console
You may have to adjust the POT of the GameCube lens... The POT is basically the power and spread the lens uses to read discs... the problem is, over a long period of time, the POT figure drops down, and if it drops too low, you will need to replace the lens.. The machine could still be salvageable, and play games and load them faster than before if you adjust the POT on the machine.. Here is a guide on what is required to open up the machine and do it, if you feel it necessary.... http://modthatcube.pxn-os.com/content/pot.htm
SOURCE: wii console
Did you try turning the disk over so the label shows on the opposite side. With the Wii you have to put them in upside down it seems.
SOURCE: wii error reading disc
If Wii gives Error reading disc, first step you need to check is to try another disc or clean the exisitng disc. This will confirm that problem is with either Wii or Disc. If the console itself is giving disc read error then it needs to be repaired. You may check out DIY Wii Fix Guide, that will show step by step information to fix the problem yourself. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
