Question about Olympus Camedia C-5060 Wide Zoom Digital Camera
Error message, error creating olymrye service 1072, the service was deleted and when trying to add back, this error message pops up.
Posted by cassandra_mc on
Wont login
back up ur data by login safemode by pressing f8 when pc starts
backup all user data
create new user account and delete old account
I have been trying to get on facebook but everytime I try an error message from Internet Explorer pops up saying "cannot display webpage" Please help
Open Internet Explorer, click on tools then internet options. In the first tab, under browsing history select delete... have check marks in everything except Form data, Passwords, and InPrivate Filtering data. Now click delete. Depending on how full you histroy is, this can take a bit to complete. Once completed, close IE and try to log back into facebook. If this still does not work, search for facebook on google, and try again. If the search option works, delete you current shortcut to facebook and re-add from the open page.
I hope this helps
E66 wont send a text, message goes straight to out box. can make and take calls, rcves texts but wont broadcast...swapped sim to another handset and works fine ??? any ideas ..Thanks martin
this problem is due to the text message service center number
text message service center number option is available text message settings
in this you can see service center number
Note down on any paper as it is (+9198xxxxxxxx)
then delete the service center number
after deleting create or add the new service center number
in this you fill the same number which you note down in your copy
save it and go back to main screen
then restart your phone
your can than send/ receive messages
if it not works go to the shop and get the text message service center number and follow the same procedure but the number you fill is you get from the shop. (NOT THAT NUMBER WHICH YOU NOTE DOWN IN YOUR COPY).
good luck
rate it
3answers
Error! Press shutter release button again
OK, don't worry. The repair is easy to be done, although a little "creepy". I have a girlfriend who owns a Nikon D60 which presented the very same problem, and this afternoon I repaired the camera myself. It's working very well so far. Here's how I did it.
First of all, check whether the menus are working properly. If they are, it means that the problem is not electronic (otherwise, it should provoke a general camera lock down).
Get the following equipment:
1) A very small cross head screwdriver (watchmaker size)
2) A can of WD40 (lub oil) - that one that has a little plastic tube for delicate jobs.
3) Double faced sticky tape
4) Printing paper (A4 size), and pen/pencil.
5) A good light
Remove the camera's Battery and SD card.
On the A4 paper, draw the bottom scheme of the camera with the position of the screws; on each position, place a little piece of double-faced sticky tape (so you'll be able to know exactly where each screw must be put into). You''l need two drawings, one for the camera's outter plastic cover and the other for the inner steel plate.
Open up the bottom of the D40x putting the small screws onto the sticky tape in the corresponding positions.
Then, remove the metal plate used for the tripod mount. You will need to remove the back of the camera as well.
All the screws must go for the correct corresponding places on the A4 paper scheme, otherwise you will find hard to put all the parts together again.
After you have the bottom of the camera open, you'll see small gears, one red and one white. They are there to transfer the up-and-down movement from the small motor to the camera's mirror, and they should be stuck due to lack of lubrication. If you move the red gear, you'll see the mirror moving together. Spray a SMALL amount of WD40 onto the red and white gear wheels. Don't use so much that it drips down onto the optics or the delicate electronic circuits - you don't want any oil in there!!!
After the oiling is done, put the battery in and hold it down to make contact. Switch the camera to MANUAL mode. Put in the SD card and switch on the camera. Thereafter, try its shutter button.
It might start working normally, without any error messages. If it's not moving, probably the oil has not spread properly yet throughout the red and the white gears. Move the red wheel a few stops and try again.
Once it's lubed up and the wheels move freely, camera should be ok. Before settling all the covers back to their places, keep taking pics until you feel that the camera is functioning normally. Probably you'll note that the error message will be gone.
Then reassemble the camera's parts following the screws backwards on the sticky tape.
Enjoy your camera again!
2helpful
3answers
Hey, how can I turn off prompting ICQ Zones?
go to Run then type MSCONFIG to open Microsoft Configuration then select STARTUP and Disable ICQ command.. Good luck!
2answers
Yahoo messenger list
This looks to be a problem with Yahoo itself.
Try writing to yahoo technical team.
Link as below.
http://help.yahoo.com/l/us/yahoo/messenger/contactus/contactus-01.html
Pop3 email account connection error
you most likely have an error in your pop3 settings exchange server also suppport imap see if you can delete the outlook settings and then create a new connection using the correct pop 3 information or try imap ask your system admin what the imap settings are because pop 3 is no longer used as much
Feb 16, 2018 • HTC G1
Olympus Camedia C-5060 Wide Zoom Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
