On my 2002 F150 super crew,I need to locate the passenger side door ajar circuit wire. I am attaching a power step and need to locate the wire. The instructions say its a back with pink stripe wire in a bundle behind the door panel. No such color. I am thinking its one of the five wires to the electric door lock switch. thank you.
The door ajar wire is the Black w/ Pinks tripe wire, on the SuperCrew the driver's door is solo, and the other 3 are are in the same input to the GEM.
The passenger's side kick panel ( the plastic that covers the Fuel inertia switch ) is a connector C206, right above C203. There is another smaller looking connector above C206, and some small 2 pin ones shown back there, along with 2 ground lugs in the side of the cab sheet metal.
C206 is a square 16 pin connector, 4 pins by 4 rows.
C203 is also a square 16 pin connector, 4 pins by 4 rows.
The higher of the 2 connectors is the one you want, the Black w/ Pink stripe wire is in the outside column, 2nd to the last from the side farthest from the tab.
Looking at the connector with the tab on the top, the outside column should be ( from tab end ) :
pin #1 : Dark Green w/ Orange Stripe
pin #5 : White w/ Light Green stripe
pin #9 : Black w/ Pink Stripe <- This is the one for all 3 doors
pin #13 : ( bottom ) White w/ Light Blue stripe wire
The connector is numbered on the top row, under the tab ( that is why the pin #s are spaced out reading down the column ).
The wire in the door is in a loom, it is coming from the door latch ( that is where the switch is at ), so it might not be obvious.
It should not be in the connector for the door lock switch ( that is Pink w/ Black stripe wire, not the same ).
