The picture freezes for about 10 minutes then fades to a raibow color immediately followed by a black screen. The TV is less than two years old and is utilized at best 3 hours a day.
Check to make sure that off the air broadcast (not cable) is having same symptoms. A good chance main board is the problem. If it is less than 12 months old, contact Samsung for warranty service.
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Search the site with the keyword "Line fault"
Sounds like possibly it could be connection related between any AV/Cable ports. Worst case would be the capacitors of the motherboard leaking. It's possible to fix anything. Just make sure you have the knowledge and the right equipment.
We have a 60" panasonic rear projection television and the color fades in and out. What do you think is the problem the tv is only two years old and is now starting to apear in black and white sometimes. What can be the problem?
When you let it sit for approx. 15 minutes it will come back on and usually stay on. I've also noticed that the color will fade in and out at times.
during 15 mts of your sitting do you get sound & less brightness then problem in video or luminance section.
if picture is dim & color will fade in and out at times then possibility of crt is getting less voltage on g2.
if set is old then there is a possibility of crt getting weak.
but if the above things are not there then problem in power supply.
good luck
