SanDisk Sansa MP3 Player Logo
Posted on Nov 23, 2009
My sansa mp3 player will not charge or come on when i hook it up to the cmputer nothing happens
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
189
Points
My sandisk sansa exprese,mp3 not working if a battrey how i can replec the battrey i cant open.
1helpful
Sansa 280 MP3 player won't charge. When attempting to charge, it
This problem indicates that it is stuck from inside . You just keep on pressing menu option and keep on pressing the center button for 2 minutes it will solve your problem .
It actually worked for me that's why I am sharing this .
If you still have a problem let me know .
Hope this helps .
Do rate my solution .
Computer doesn't notice MP3 player
the requirments are not made. i had the dame problem, just download sansa updater installed, can you help my problem
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
2answers
My sandisk sansa is not detected by cmputer?
plug it into your usb port and open your MY COMPUTER menu and it should be listed under drives just like a disc or floppy
Mp3player
sansa fuzzmp3 player,wont turn on or charge up,what happened? I did nothing to it but put it in my pocket as usual...Help please
2answers
Nothing happens when I click on Menu button
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Start the computer program before you plug in the View??
FROZEN!!! PLEASE HELP!!!
DEFRAG IN MSC! Then check, then format.
Found here, worked for me:
search: format sansa c150
www.fixya.com/support/t137630-mtp_db_mismatch_format
Top SanDisk Audio Players & Recorders Experts
SmartAviator
SmartAviator
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
