Question about Yahoo Messenger
I cant sign in on my messenger and see error 81003002. please help
Posted by smbenauro on
Anonymous
    Guru:
  • 1,738 Answers
Tip
How to fix Yahoo! Messenger sign in error 81003002
Follow the Below link to fix the Yahoo Messenger sign in error 81003002 aloong with the screen shots<br /> <br /> <b><a href="http://tinyurl.com/81003002">http://tinyurl.com/81003002</a></b><br /> <br /> <b>All the Best.....</b><br /> <br />
on Dec 16, 2010 | Computers & Internet
Yahoo messenger erroe 81003002
This error code indicates a sign in problem with Yahoo messenger. Try some of the following tips to resolve the issue.
-Make sure you are entering in the correct log in credentials. When the error pops up, there is a "Sign in Problem" button you can click on for further assistance.
-Make sure your computer is not infected by a virus. This has been known to cause this error.
-On Windows, Press Ctrl + Alt + Delete and bring up task manager. In task manager, go to the processes tab, and in the process list look for something like yahoomessenger.exe. Highlight and click end process. Now run yahoo messenger and try to log in.
If the above does not work, uninstall yahoo messenger and reinstall.
Regards,
G33k
May 15, 2011 | Yahoo Messenger
I can not sig in my account and get 81003002 error.I am compeletly sure tahat may ID and password is correct
Here's what you need to do in case you encountered Yahoo messenger error 81003002:
  • Double check your Yahoo ID and password. If at several times of sign in attempts but you still get the same error, restart you PC and if you are connected to a modem or router, do the same.
If you are sure that no virus has actually penetrated the system, there is no need to run a system scan.
  • While some blogs advice reinstallation of the software (of the same verision, i.e. v9) and some may even advice removal of v.9 and installation on an older Yahoo messenger version like Yahoo Messenger 8, do not waste your time as I have already done that. The older version of the IM software no longer works.
Again, if you have had error 81003002 while atte
Feb 24, 2011 | Computers & Internet
Error 81003002
Check you password is correct...try log in with webmail...http://login.yahoo.com or http://webmessenger.yahoo.com ... please let us know...
Thanks
Dec 21, 2009 | Yahoo Messenger
Cant open Yahoo Messeger to read emails error 81003002
am sure your computer has registry problems.It is very easy to repair yahoo messenger 81003002 error. you just need 3 steps:
1: Download a registry cleaner and install it.
2: Open the registry cleaner and scan you computer for free
3: Click fix button and you done.
Download the top yahoo messenger 81003002 error repair tool here:http://www.fixerror2009.com/tidpp-yahoo_messenger_81003002_error-zz0001
Sep 20, 2009 | Yahoo Messenger
Experiencing error (81003002)
common error..log off and log back in..sometimes you have to restart your pc..
Sep 18, 2009 | Yahoo Messenger
I have a similar problem, i cant log in in my desktop and laptop
Uninstall the yahoo messenger from you computer and re-install it to resolve this issue.
Please revert with the result
Sep 01, 2009 | Yahoo Messenger
Error 81003002
You may be have 3 options to solve your problems:
Try this:-
1. Go to Messenger>Connection Preferences> then, you choose either connection directly to the internet or connect via a proxy server, and then choose type of internet connection>OK>Sign in again... let's try this, may be you can solve this problem. OR
2. Maybe, i think you should check your firewall settings. If you use Personal Firewall, make sure it allows your connection to receiving incoming connections and allows you to use yahoo messenger,check it out, may be it blocked your yahoo messenger. OR
3. Open your Internet Explorer>Go to File>Then, 'uncheck Work Offline', make sure your Internet connection is not working offline. Then, close Internet Explorer, try to sign in your yahoo messenger.
Good Luck!
May 30, 2009 | Yahoo Messenger
Yahoo Messenger Logo
326 people viewed this question
Top Yahoo Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
Mike
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
