Vtech V.Smile TV Learning System Logo
Posted on Nov 23, 2009
V tech new item..motion console..worked..turned it off turned it on..wont work
Anonymous
Level 1:
New Friend:
  • Contributor 8 Answers
  • Posted on Feb 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
8
Questions
0
Helped
2610
Points
11
Make surt you did the steps in the right order. Start with the TV and Vsmile OFF.
step 1) put the cartridge in and make sure it's all the way in
step 2) turn the TV on
step 3) turn the Vsmile on
if it still doesn't work, try taking the batteries out or unplug the adapter to let it clear and then try the steps again.
2helpful
Why does my Nintendo 64 console keep on continuing to be in slow motion then ?
My N 64 console goes in slow motion as well too. It could be the ac adapter might be causing this problem here so try a new ac adapter to see if it solves the problem or it could be the power outlet as well that is not putting out the proper power to the console or it needs to be cleaned out. Or the video chip went bad and the slow motion is occurring. The jumper pack or the expansion pack could be starting to go bad and needs to be replaced and it is warning you that the jumper or the expansion pack is going bad and will stop working anytime and the game will freeze and then turn all black and then blank out on you and you will go to the screen on the TV after that. Sometimes the expansion and the jumper packs can quit working with no warnings at all to let you know. Or it can say on the TV screen expansion pack or jumper pack is needed. I have tried a new expansion pack for my N 64 console and it is working fine again it could just be that.
I have a wall mounted Craftsman Premium Control Console with a motion detection sensor to turn the door opener light on when I enter the garage. Will it work with a new Sears Garage Door Opener?
Look at the manual that came with your new opener. If there is a wire that is denoted "garage opener light" then yes it should work. Craftsman Control Console Premium
The description says for Sears Garage Openers since 1995.
My Big Ben controller wont sync
maybe you should just refund the item and get a new one?
Motion Controls on remote are not working
There is a very small circuit element inside the wiimote called an "accelerometer" (it heats a small vacuumed area to sense yaw, pitch and roll with thermometers).
It sounds to me like you have a malfunctioning accelerometer, which could be replaced in theory-- that sounds like an exciting challenge to someone whose electrically inclined, such as myself. However, doing so would require finding the correct replacement online and substantial soldering skills to replace it.
My wii wont turn on at all--and its brand new
if u left the wii on for a long time it wont work any more so i suggest going to tech support for more solutions.
Cartdride wont read
Take a can of air and blow it into the cartridge slot on the N64. Then also whatever game you decide you want to play, take a q-tip and dip it into some water, then clean the contacts on both sides of the cartridge in a sweeping motion. That will remove the dirt thats on the contacts. Then take a dry q-tip and wipe off both sides of the contacts of the cartridge.
That should resolve it. If it doesn't, try a few more cartridges and clean them and at that point if the system still won't load the cartridges properly then the main board is bad and you would need a new system.
My ps2 wont play guitar hero metallica what do i do i cant take it back?
Make sure it plays any other game. If it does, then breathe on the disc like your fogging it up with hot steam, then wipe it off with a soft towel in a circular motion, if still does not work. Need a new game.
Wii remote stop working when I was playing Super Mario Galazy?
You may not be making the correct motion. It took me a couple of tries. The motion you use for this is to shake the Wii Remote like a can of spray paint or... kind of like a bottle of orange juice.
Hp mouse problem
Hi my new hp bluetooth laser mouse does not work. It will work, then when you switch users, or turn off the computer and then turn it back on, it stops working and will not work after that.
Top Vtech Toys Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Vtech Toy Expert? Answer questions, earn points and help others
