Question about Vacuums
Dirt devil breeze upright-- need to know how to change belt
Posted by skn100 on
Vac Belts
  • 701 Answers
Here is a link to the manual and to the belt you need:
Dirt Devil Breeze Manual (PDF)
Dirt Devil Breeze Belt
Posted on Nov 24, 2009
Why does the belt keeps comming off
Hello! If your belt keeps coming off, this usually means the belt is stretched and needs to be replaced. The Dirt Devil Breeze takes a Dirt Devil style 4 belt. Follow the link below to purchase the replacement belt. Hope this helps!
Style 4
Apr 28, 2014 | Dirt Devil Breeze Bagged Upright
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Bush roller squelling on dirt devil 130005 upright bagless cyclonic vacum
My dirt devil has 3 screws underneath- these are the same ones you use to change the belt--sounds like something is caught in roller-- mone was full of hair!
Jan 02, 2014 | Dirt Devil M130000 ''i'' Dual Cyclonic...
Vacuum Belt keep breaking
When your first belt burnt, the burnt plastics goes into the roller ends and then it dries off causing your roller to not turn or put more pressure on your belt. Until you clean that you will continue burning your belts soon after you put them in. You need to add a little bit of WD40 or any other type of lubricant after you remove the tar from the roller.
Feb 26, 2010 | Dirt Devil Breeze Bagless VacuumVacuum
Belt pulley is broken
sad to say but as far as i know you cannot get any parts for dirt devil vacs only filters and belts and bags sorry
Nov 03, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Wont shut off when I press the power button
the switch has failed inside the unit so it is stuck in the on position
Oct 27, 2009 | Dirt Devil Featherlite Deluxe Bagged...
I don't know how to change the belt on the dirt devil ultra vision no manual
Take all the screws off the bottom to access the beater bar than slide out (belt will also be right there ) just slide a new one on......
Jan 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Missing belt
Thanks for the info **** now stick it up your ***!
Nov 19, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Vacuums Logo
276 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
