Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint gas oven won't keep its temperature. I
My Hotpoint gas oven won't keep its temperature. I turn it on to say 400, it preheats, beeps, I put food in, and then the heat seems to shut off, or drop down to say 150. If I turn the oven off, then on again, it heats up, then eventually drops in temp again. What's with that?
Posted by tina_kussey on
  • Anonymous Mar 30, 2014
    I have a Kenmore gas stove and when I turn the temperature on to heat it will say oven on but will not cook food what am I doing wrong
steve
  • Hotpoint Master
  • 3,361 Answers
The temperature sensor in the oven needs replacing. It is located in the back wall of the oven. About 3 inches long,metal and about the size of a thin pencil.
Posted on Nov 22, 2009
How to change lower element in DeLonghi Airstream Convectio Oven
  • How to change lower element in DeLonghi Airstream Convectio Oven??
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Oct 28, 2017 | DeLonghi Ovens
    Is it dangerest when your oven beeps f2
    Typically an oven beeps when the interior temperature macthes the temperature where you set the dial. This is an audible signal to that fact and particularly helpful when you need to pre-heat the oven. For example it you want to cook something at 350 degrees, you set the dial at 350. When your oven reaches that temperature it beeps to let you know. Some cooking directions tell you to preheat your oven. In that case, when you set the dial to 350 and wait for the beep...you know you are safe to start your cooking process because the oven is now pre-heated to the temperature you set. If your recipe requires a pre-heated oven, and you don't wait for the beep, your taking a guess at what temperature you're cooking your food. Additionally, if you want to know what the internal temperature of oven is and your oven is heated...you simply turn you dial setting and listen for the beep. Again, if you set your oven at 350 and you want to know how hot your oven is... slowly turn the dial setting. If the oven beeps at 275 then that's how hot your oven has gotten. To let it finish heating to 350 just reset the dial and wait for the beep.
    Jan 13, 2012 | Stoves 600GR Gas Single Oven
    I turn the oven on and set the temperature 5 mins later I check on the food and the oven has turned itself off and displays stop on the LED.
    Is it gas or electric? If it is gas it sounds like the ignitor is bad keeping the oven from heating up. Does it preheat and then go off or never heat up?
    Feb 25, 2011 | Ovens
    I need to learn how to use my oven, because i don't know how to turn it on.i need to bake,so can u tell me how?
    You can get the manual for the RGB745 at the GE Appliances support site: http://www.geappliances.com/service_and_support/literature/ . Enter the model number in the search box. There are several models that start with RGB745.
    On most of the Hotpoint ovens for regular baking, press Bake and use the + or - buttons to set the desired oven temperature. Then press Start/On. Then the oven will display Pre as it re-heats. When the thermostat indicates the desired temperature is reached, the oven will beep. The racks should be on the middle positions for most baking. (For roasting use the lowest positions.) Put the food in when the oven is done preheating. When done, press Clear/Off. Timed baked requires the clock be set correctly, then set the start and end times.
    For the older ovens with dials to control the oven, set the first dial to Bake and the second to the desired temperature. Wait at least 10 minutes for the oven to preheat. Again put the oven racks in the middle of the oven for most baking.
    Do not lock the oven latch and keep the oven closed through the baking cycle as much as possible. (Rotating pans and basting steps should be done quickly so that the oven doesn't cool much.)
    I hope this helps.
    Feb 11, 2011 | Hotpoint RGB745 Gas Kitchen Range
    The oven preheats, but then "cools down" before I
    Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
    Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
    How to change the lower element on a delonghi AD 699 toaster oven?
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Preheat takes forever
    http://www.applianceaid.com/nuker.html
    click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
    Some ohm readings and there temperature:
    Degrees F    -   Resistance
                100 - 1143 ohms
                 200 - 1350 ohms
                 300 - 1553 ohms
                 350 - 1654 ohms
                 400 - 1753 ohms
                500 - 1949 ohms
    click this link
    http://www.applianceaid.com/elecrange.html
    Mar 01, 2009 | GE Ovens
    Preheating
    hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
    May 12, 2008 | Ovens
    try changing the oven sensor its in the oven looks like a small rod coming out you need to remove 2 phillip screws the take it out
    Jun 08, 2007 | Hotpoint RGB745 Gas Kitchen Range
    Hotpoint RGB745 Gas Kitchen Range Logo
    1,825 people viewed this question
    Top Hotpoint Kitchen Ranges Experts
    Fahr Quad
    jdthefixer
    Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
