Question about Zenith Analog to Digital Audio Converter
Dtt901 does not work. I unhooked it for a month, and when I hooked it back up, it won't work. The blue light and red lights go on, I have tried using different connection cables and the TV works fine to play dvds (its a small 12 in tv with built in dvd player.) Why would it not work, from just being disconnected for a month? nothing has changed, same tv, same outlet, etc.
Posted by cindyloose on
electracon
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Could be something to do with the date and time. It seems like they like to revert back to 12/31/14 fr some reason and the time will be off due do connection. Go to settings and first turn off auto time and then change date and change time and year then it should work ok.
Posted on Sep 08, 2017
5 Related Answers
Anonymous
  • 64 Answers
SOURCE: how do i hook this to tv or digital cable to get surround sound?
Sorry to say, Circuit City is right. These cheap home theatre in a box solutions are very very shady. They put the DVD player, preamp, and reciever all in one little box. Not very handy to adding options or plugs but very very cheap to produce. Ever notice why large home treaters have about 5 big black boxes and a DVD player? This little box is trying to be all of them. If this was a reciever combo(as zenith wants you to think) then you could do EVERYTHING you were thinking would just make sense. Unfortunately, you trusted Zenith instead of Circuit City(gah i hate saying that). At any rate, if you still have receipt, return it!!!! I will help you pick a system to suite your needs. I do all the things you want on a system i got for 500 bucks.
Posted on Jul 26, 2007
Anonymous
  • 319 Answers
SOURCE: Having problem with GPX DVD Player
Do you have the product manual?
Posted on Jan 10, 2008
Anonymous
  • 76 Answers
SOURCE: No Sound
possibly the sound part of the DVD player went out it happens all the time but to get it fixed you have to take it to a repair shop. Hope this helps =)
Posted on Feb 25, 2008
Anonymous
  • 52 Answers
SOURCE: DVD cables
You have to plug your DVD cables into the "input" connectors on your tv. Input audio and input video. Also there is either a switch on the back of your tv or in your menu where you have to choose "component video". Or it might be labled Video 1, Video 2, Video 3, etc. You might have both a switch on your TV and a choice in your menu. If so, both have to be set to "component Video. Sometimes on the back of your set, the switch is not labeled. It just has "arrowed" lines coming from the different switch positions and leading to the "outputs and inputs" on the back of the set. Set the switch so that the lines lead to the red, blue and green INPUTS on the back of your set. Your problem is not serious. It is just a matter of "telling" your TV that you are using "component video". Component video is when you are using the red, blue, and green inputs. It is also possible that your DVD has another output besides "component out" and also has a switch. Make sure this switch on the back of your DVD is in the "component OUT" position. Your DVD might also have a connector on the back that looks like connectors on the back of VCR's and most TVs. This is an "F" connector and the cable has to be screwed on. It's just like a cable tv cable. Screw a cable into the "out to tv" on the back of your DVD and screw the other end of the cable into the "RF" INPUT (or cable input) connector on the back of your tv. Be sure to look ALL through your TV menu and DVD menu. The DVD sets to "component OUT" and the TV sets to "component IN". Hope this helps.
Keever
Posted on Mar 04, 2008
Anonymous
SOURCE: cant get dvd to operate
Have you changed the TV input to AUX? If there is a VCR hooked up with your satellite box it has to be on Line or Aux too. Make sure these are in place before trying the DVD player
Posted on Jan 28, 2009
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Dtv tuner DTT901 no power for red and blue light
Dear Friend,
I am not sure if this question involves PS3 or a Digital Box but, it looks like you are trying to resolve some issues with your Digital Box from Zenith if I not mistaken.
First, if there is no reset button in the back, press the power button for about 30 seconds and release it, the light usually flash or goes on and off.
Second, If the above step does not work I suggest you to replace, return or contact Zenith for warranty.
Third, try a another brand since people have too much issue with Digital boxes from Zenith.
Good Luck!!!.
Nov 04, 2011 | Sony Playstation 3 (PS3) Console
Red light at power on
Too bad. The quickest/cheapest way to proceed is to buy another router, either online (through 'www.UsedEverywhere.com') or at a "big-box" consumer electronics store, for less than $50.
Aug 01, 2010 | Linksys Wireless-G WRT54GS Router...
Ignition switch harness in 2008 sebring
the wires you will need come right off the back of the ignition switch, use a logic safe probe or a digital mutimeter
Jan 09, 2010 | 2008 Chrysler Sebring Convertible
Electric trailer brake hookup
Truck Brake control
Red/Black stripe Black
Blue Blue
Lt. Blue/white stripe Red
White White
Orange Not used
Jun 28, 2009 | 2006 Toyota Tacoma
Led light
The light that used to stay on all the time is most likly the Power light(LED) The light that used to flash when you were using the computer is the  HddLED(Hard disk drive Light Emitting Diode) If you mixed them up it wil likly only light the wrong light.    I hope this helps.  If you wish to be sure you may be able to download the owners manual  the manufacture ?
Oct 02, 2008 | Gateway GT5220 PC Desktop
PS3 or LCD TV?
when the ps3 is in standby hold down the power button for over 4 seconds, it runs the optimal screen settings page. hope this helps
Feb 26, 2008 | Sony Playstation 3 (PS3) Console
Red light
something is shorted in the circuit, or your subs. unhook the subs first and try it again, if it is still in protect then it is most likely the output transistors.
Feb 22, 2008 | Sony Xplod XM-554ZR Car Audio Amplifier
Zenith  Analog to Digital Audio Converter Logo
70 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
