Fujitsu Lifebook S7020. Powers up but no display, even on external vga. I have tried to remove battery and press power button.. After one attempt this got the display back working but the pc froze on windows start up. Since restart now no display again. Any ideas?
remove rhe 2 screws which have arrows pointing to them either side of battery and screws underneath battery, remove top cover with speaker grills and power button, remove 2 screws at top of keyboard, remove keyboard, if you want more access, remove rest of covers, screws, dvd-rw and screws beneath dvd-rw gently prise casing apart, remove screws from mobo, remove mobo.
I found this in my archive, it is not the S7020 but it is the S7010. I believe they have the same case design, so this will most likely work for you. It is a aolor picture guide to the disassembly of the laptop.
Have you tried draining the static on your computer?
Turn off the computer remove the battery and adapter press and hold the power button for 1 minute plugged back in the adapter and battery turned on the computer
if not resolved:
tried using an external monitor and connect to your computer to check if you can have a video on the external, if yes it is possible an LCD issue
Also, you may try using a flashlight in your LCD and check if you can see any, if none?
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
The Inverter board must be tested and eventually replaced. The inverter is the small board located at the base of display. This is connected to one side to the backlight lamp, to which supplies AC high voltage, and on the other side to motherboard, where receives DC voltage.
Inverter contacts to otherboard and to lamp must be tested , using a multimeter to read volts. The inverter is an AC board, and for safety reason the test must be done by a trained repairer. If the inverter is OK check the contacts to motherboard and wiring harness to motherboard..
Also ensure that light is not just dimmer because energy save mode is on, or because the laptop is running on batteries.
actually in these case laptop does'nt display due to many causes some might be in vga chips, inverter, and LCD etc. but in these side first check if light indicators normal all. then check the inverter.
