water stopped dispersing out of water dispense, No indication as to why. New filter was instlled, checked water line, no leakage indicated, ice maker had been making ice prior to this, turned off ice maker to avoid motor burn out.
I have a similar problem for my LSC27911ST. There is no water coming out from the dispenser, although ice maker seems to be working.
I didn't do anything other than keep trying water dispenser in hope that water can be drawn out from the inner pipes.
After opening the freezer door a number of times, tried dispense ice and then tried dispensing water a number of times, eventually water come out again.
Maybe the water line in the refrigerator was frozen. It is very hot today, and maybe the refrigerator over work too much.
The water line is freezing in the door due to deteriorated insulation. The only fix I have found to work on my fridge was to defrost the inside door with a blow dryer. Then place a weedeater replacement line (the orange 10" or so size you find at Lowes' or Home Depot) up through the dispenser nozzle, If the line only travels about 3-4 inches up the nozzle, then ice is still in the tube. Blow dry it until you are able to get water to dispense. After the tube is ice-free, place the weedeater line up throuth the dispenser nozzle leaving about 1/8" sticking out. The dispenser will still work with the line stuck in it. The dispenser will probably freeze again in about 8 hours, But all you need to do each time this happens is to pull the weedeater line out, dispense the water to unclog the ice, and place the weedeater line back in the nozzle. I have been using this method for about a week now and it works great. My GE Side-by-side is also 4 years old and this seems to be a problem with all of them. There is a part you can order to fix the problem, but I have heard it may not work.
You'll need to replace the whole ice maker system. Problem exist in the mechanical box connected to the lever which once opened is almost impossible to re-assemble. Cost around $95.00
You may have a bad water valve. The valve has 2 sections, one for the water dispenser and the other for the ice maker. Check those connections in the back of the refrigerator. If everything is ok, replace the water valve.
It is possible that the water valve behind the refrigerator is either defective or the wire connection is loose. Also check the fill tube where the water comes in and see if there is ice blocking the fill tube. Since it's under warranty, have it serviced by the LG warranty to resolve this issue.
