My tv just starting randomly turning itself of and back on. I can here it clicking on and off several times before it restores itself. It has done this about 6 times today.
I replace the whole power supply and that fixed the problem. I found one for $132 fromhttp://www.partstore.comI replace the whole power supply and that fixed the problem. I found one for $132 from http://www.partstore.com
You can't post conmments that contain an email address.
That is a plasma and usually power supply board. ebay search your model number. Also look for blink codes on front if it locks up. lastly check for software upgrades for you model thru google
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
If the tv is still under warranty, this can be repaired at no charge.
However, if not under warranty, you will need to have the CAPACITORS on the main power supply circuit board tested (or replaced).
The capacitors responsible for the power supply can sometimes fail - open the back panel. If the capacitors on the main power supply board look too fat, or signs of burning near the solder joints, then you've found the problem.
