Question about Toshiba TZ50V51 50" Rear Projection Television
If the TV looks zig zag or scrambled and its moving aroudn the screen the hypermodule has failed.
If however it looks 3D or warped and is not moving around the convergence is the issue. You can get DIY repair kits including all parts, instructions, and support from sites such as www.TvRepairKits.com
Posted on May 01, 2011
The plastic screen on the front ov the telly has crack
Posted on Feb 20, 2010
Good Day,
The TV has a convergence problem; the IC’s for that circuit will need to be replaced. The cost for this repair runs around $450.00 or more.
Replace the defective Convergence Output IC Part Number
23905094 (STK392-110) using the revised “T” version IC Part Number
23135090 (STK392-110T). When Convergence Output failure is
detected, it’s recommended that both IC’s be changed to the “T” type IC
version. Inspect the Convergence Output IC’s for the “T” type version as
shown in Figure 2. Replace the Convergence Output IC’s using the “T”
type version Part Number 23135090 (STK392-110T).
Thanks for choosing FixYA, Big Irish
Posted on Nov 23, 2009
Howdy,
Make sure the updated parts are installed:
Replace the defective Convergence Output IC Part Number 23905094 (STK392-110) using the revised “T” version IC Part Number 23135090 (STK392-110T). When Convergence Output failure is detected, it’s recommended that both IC’s be changed to the “T” type IC version. Inspect the Convergence Output IC’s for the “T” type version as shown in Figure 2. Replace the Convergence Output IC’s using the “T” type version Part Number 23135090 (STK392-110T).
1420-B Toshiba Dr.
Lebanon, TN 37087
Fax: 615-444-7520
www.tacpservice.toshiba.com/tacp
© 2005
Thanks for choosing FixYA, Big Irish.
Oct 24, 2011 | Toshiba 50H71 50" Rear Projection...
Apr 24, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
May 06, 2010 | Toshiba 55H70 55" Rear Projection...
Jun 16, 2008 | Hitachi 50UX57B 50" Rear Projection...
May 24, 2008 | Toshiba 50H71 50" Rear Projection...
May 18, 2008 | Toshiba 50H71 50" Rear Projection...
Apr 10, 2008 | Toshiba 50H71 50" Rear Projection...
Mar 26, 2008 | Toshiba 50H71 50" Rear Projection...
Mar 20, 2008 | Toshiba 50H82 50" Rear Projection...
Feb 05, 2018 | Toshiba TZ50V51 50" Rear Projection...
435 people viewed this question
