I have a Sony Model #KP-51WS520 and when I attempt to power it on I receive nine flashing red blinks, then nothing for a few seconds, then another nine flashing red blinks. I have attempted several times to unplug the unit and power on after a minute and still the same reaction.
Count the number of flashes in between a slight pause and see if its a 9 blink error or not. Then let me know how many blinks the red light is doing and I will assist you with the issue
Standby flashing light shows that tv got some internal problem. How many times standby light is flashing is info that provide info about what section of tv got problem. Count standby light blinks and let me know, there would be 3 seconds long pause in blinks so count pause to pause.
Nine Blinks- Replace D6116 and D6301 on the "G" board, do not solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
The flashes are fault codes. It means your system is faulty. If it is intermittent then it is more than likely a dust issue. Buy an air duster, spray out the back and restart. Should be fine
If it continues to play up then it will be a repair job
When a Sony TV flashes five times, that means that there is an AKB circuit fault. Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a
technician, as several IC and components must be tested and eventually
replaced.
Heres what the 6 blinks means with your model. Here is a link where you can gey the full service manual for your set with trouble shooting and full part number list. they email them Instantly after purchase
• +5 line is overloaded.
(A and BM Boards)
• +5 line is shorted. (A and BM Boards)
• IC303 is faulty. (A Board)
