There is no default pairing code for the phone. You have to enter any pairing code and then enter the same pairing code in other device.
However, if you are trying to pair Bluetooth headset, check the headset manual to find its default pairing code.
Pairing the headset with a phone is a simple task: just hold the multi-function button for an extra few seconds when turning the H500 on, and the blue LED call indicator will turn on. This means that the headset is ready to be paired, and can be discovered with any phone, PDA, or computer that supports the headset or hands free Bluetooth profiles. As is the case for most headsets on the market, the PIN code for the H500 is "0000".
you just need to pop out the back case in order to see the mainboard of your pocket pc.
try first whit your nails, and if you can't, then use a plane screwdriver.... but try firs whit nails cause screwdrivers can harm or scratch your case.
blinking red and green means the headset is in pairing mode and ready to be connected to your phone. This means it is either the first time you have paired the headset or you have depressed the volume +/- buttons simultaneously for more than 5 seconds. If your phone cannot find the headset, it may be a compatibility issue. Try pairing the headset with a friends phone, possibly a sony ericsson. Good luck.
I have many a time wanted to increase the main memory in my PDA. Sadly, there is no way to upgrade the main memory (unless you are handy at soldering, regulating voltages, and all that fun stuff). I have seen some web sites that upgraded older Palm's main memory but never an IPAQ (ie. Pocket PC).
I suggest removing the older program before installing the newer version. If you have addresses saved in the program, I would first save those to a differnt file so that the uninstall does not delete them.
To uninstall the program from the PDA tap the windows button, tap settings, tap the system tab, tap memory, and finally the remove programs link near the bottom of the screen. A list will appear with all the programs loaded on your PDA. Just tap the one you want and then tap remove.
