It's having problems communicating with the server from the sound of it. Try hard wiring your router to your ps3 and then see how you go. If that solves the problem then you may have to look at setting up port forwarding on your router
Testimonial: "Thnak you for your help have you ever had that problem and also my wireless connection in 54mbs thats strong connection isn't it"
80710723 Possible Port Error - Try opening ports , TCP port: 80, 443, 5223 and UDP port: 3478, 3479, 3658. or add Ps3 to DMZ
You really might want to try creating the connections again on your PS3 system on the same modem/router you are using.
Just re-configure you connection settings and see if that helps.
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
